![]() (Displaying no. |
Letter 36013 Ways to mask a surface prior to powder coating+++++ We are engaged in sheet metal fabrication. Several times we
encountered parts that need to be powder coated only on the outer
surface or some portions of the part. Overspray is not permitted.
Currently, we are using old newspapers to mask surfaces which need
not be painted. Is that right? How to do pre-treatment when there are
papers attached to the parts? Don Mar
+++++ There are lot of masking tapes available in India. We are using laminated busbars with powder coating. Where the busbar joints are there we use masking tape on that portion to cover it. After powder coating process we remove this tape and wash the busbar with petrol and isopropyle solution. This serves our purpose. You can also inquire fro some of the paper based tapes which can withstand oven temperature required for powder coating. Ahmed Syed
+++++ I think you should choose masket based on the following thing: the
quantity of your product. Jia
Dear Reader, please --
Save
