Pickling incoloy-800 (Stainless Steel)
Does any one can recommend a process to pickle the incoloy 800 (iron-nickel-chromium alloy)?
Saludos.
Guillermo Castorena Güemes
- San Luis Potosi, Mexico
If you want to descale it, a mixture of 35% nitric plus 6% hydrofluoric, balance water, will do. Then, depending on your following processing you may want to passivate it or activiate it more for plating.
Guillermo Marrufo
Monterrey, NL, Mexico
Gracias! Thanks!
Guillermo Castorena
