ANALYSIS FOR SODIUM THIOCYANATE NEEDED
IS THERE AN EASIER WAY TO DO ANALYSIS FOR sodium thiocyanate [affil links] THAN WHAT OUR LAB DOES. OUR ANALYSIS: 10ML SAMPLE OF BATH; 100ML DI WATER; 15ML 20% H2SO4; 1-2ML SATURATED FERROUS AMMONIUM sulphate; TITRATE WITH 0.1N AGNO3 UNTIL RED COLOR HAS TURNED TO A WHITE ENDPOINT. THE PROBLEM I AM HAVING IS THERE IS NO VISIBLE ENDPOINT?
MIKE CAPPS
ELECTROPLATING/WWT - TENNESSEE
The first guess is inadequate agitation. Are you using a spin bar?
I believe what you need as indicator is ferric ammonium sulphate, not ferrous ammonium sulphate. Double check your procedure.
dave wichern
Dave Wichern
I don't know of another method, but we use the absence of red as the endpoint.
Trent Kaufman
Trent Kaufman
electroplater - Galva, Illinois
I NEED AN ANALYSIS METHOD WITH TITRATION FOR SODIUM THIOCYANATE CONTENT %
Bora Akturan
cement additives - Istanbul TURKEY
April 13, 2009
April 13, 2009
Hi, Bora. That was asked & answered. If you don't understand or agree with what has been offered please try to cast your question in those terms rather than re-asking an answered question. Thanks! :-)
