"Spurs" - Tool for removing wax or compounding from buffer pad
I have seen a tool used by a professional boat refinisher. She called it a "spurs". A handtool of small toothed wheels that spin when applied to a rotating buffing pad. The purpose is to remove the accumlated wax or compounding from a buffing pad.
What is the proper name of this tool and where are they generally sold?
Jonathan Caldwell
hobbyist - Stratham, New Hampshire
Spur or rake is probably correct but should be available anywhere you are buying your detailing supplies.
Dave Barr
Alloy Polishing Co. - Centralia, Washington, U.S.
