Painting brass shower fixture
I would like to paint - or at least tone down - the shiny brass around my shower stall. I read about spray painting but am afraid of the constant moisture. Is there anything you can suggest?
Kristin Hartung
hobbyist - Parkville, Missouri
If you want to tone down the shine, you might try rubbing the areas with a fine Scotch Brite pad or 00 00 steel wool [on eBay or Amazon (adv.)] (not a soap pad). You want to create a fine scratch without penetrating the lacquer. If this doesn't work, you have done the prep work for painting over the protective coating on the brass (I would use a water based paint to avoid incompatibilites which are possible with the coatings on brass).
Gene Packman
I have a brass trimmed shower enclosure and rather than replace it is there a way that I can prepare it and paint it without it peeling from the moisture in a shower?
Mary O'Keefe
Real Estate - Dallas, Texas
