Electroforming on glass
We currently electroform onto stainless steel but need to try glass. Can anyone point me to a good reference about how this is done. I know the glass surface must be metallized but I have no idea how this is achieved.
Don Peterson
electroforming / laser cutting - Lowell, Massachusetts
Silver salt reduction (like old mirrors) or palladium and tin salt (presently used for POP plating on plastic).
Guillermo Marrufo
Monterrey, NL, Mexico
You should use a conductive paint!
sara michaeli
sara michaeli signature
Sara Michaeli
Tel-Aviv-Yafo, Israel
Mr.Peterson,
You can use finely powdered silver mixed in high quality Thinner.Dip,paint or spray the mixture on the glass surface which is clean and dry.Leave the surface for one hour.Plate Acid copper carefully initially with minimum Current and without air agitation and gradually increase current and air agitation.Proceed to electroforming.
t k mohan
T.K. Mohan
