Why dilute copper sulphate with vinegar for electroplating?
what effect does vinegar [in bulk on eBay or Amazon (adv.)] have on electroplating [since most experiments ask us to dilute copper(II) sulphate with vinegar?
Charlenestudent - Singapore
It's hard to guess what the textbook author may have had in mind, especially when we haven't seen the experiment, but vinegar is a very mild acid and will help the copper stay dissolved and help provide conductivity as the copper sulphate [on eBay or Amazon (adv.)]is diluted.
It would normally be used because it is significantly safer for students to use than sulfuric acid. A plus is that it will form a copper acetate complex and tend to give you a tiny bit more uniform plating in the low current density areas.
James Watts- Navarre, Florida
