Anodize thickness
The blueprint general notes states:
HARD ANODIZE PER MIL-A-8625 / MIL-PRF-8625 [on DLA], TYPE III, CLASS 1
What is the thickness required by the spec?
Thanks in advance.
Dennis Millat
Aircraft parts - San Diego, Ca., USA
I strongly suggest you obtain a copy of the standard.
The default thickness would be .002" ± .0004 unless otherwise stated on requisition document.
Bill Grayson
- San Jose
Paragraph 3.7.2.1 under Type III coatings states " Unless otherwise specified ... the nominal thickness of the coating shall be 0.002 inch"
Chris Jurey, Past-President IHAA
Luke Engineering & Mfg. Co. Inc.
Wadsworth, Ohio
luke banner
