Letter 35037
Plating of narrow areas
[Japan]
I have a very thin groove to plate which is approx. 4mm in width
and 7mm in depth
In order to plate this, I am looking for conductive paint in order to
paint the anode.
Can anyone suggest any other options other than the above?
Kinoshita
plating shop - Japan
First of two simultaneous responses -- +++++
Mr. (or Mrs.) Kinoshita,
What is the plating and type of chemistry that you intend to use and
for what purpose (functional or decorative)? What kind of anode are
you planning to use (inert or active)? Finnally, why do you want to
paint it?
Guillermo Marrufo
Monterrey, NL, Mexico
Second of two simultaneous responses -- +++++
Hello,
I am not sure about the conductive paint but in many cases this
application can be done using the brush plating process. Brush
plating is used often for selectively plating in small areas such as
the groove you described.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
