Letter 35024
Powder Coating Aluminum Racing Rims
Hello, I own a small coating shop in Milwaukee, WI and wanted to
know if there are any dangers in powder coating aluminum rims for
race cars. Due to the stress these rims have to endure, will the
heating process weaken the aluminum or make it brittle? What is the
cut-off temperature for this? I know that many coaters currently coat
aluminum rims however I want to make sure that it is safe.
Chad Imme
Powder Coating - Milwaukee, WI, USA
The rims will only be in the oven for about 20 to 30 minutes at
375 degrees for the curing. The temperature is high enough to change
the properties of the alloy, but you need more time in the oven to do
so. In order to prevent me being the butt-end of a lawsuit, that's
all I have to say on the subject. CYA on this one.
Sheldon Taylor
supply chain electronics
Wake Forest, No. Carolina
August 8, 2006
Hello, in regards to powder coating alloy wheel rims, powder coat
in Australia has a cure temperature of 180 degrees, time in oven is
set for 15 mins to achieve full cure, alloy wheels are safely done
with out any damage due to heat of oven at above temperature, can
test full cure by impact to powder coat to see if chipping ,if not is
cured,best results is to finely abrasive blast rim to improve
adheresion,keep in mind profile depth should not exceed 30 mircos
profile depth to advoid air entrapment, application of powder should
be finely applied and avoid high film build ups ,with a little
practice you should obtain a 2 pac like finish, we use a nordson sure
coat system with a small cup mounted,amount off powder used is 1 to 1
1/2 cups per rim, cleanning use a tack cloth to clean surface of rim
prior to coating and use a fine sieve to remove fine lumps present in
powder. a word of advice do not try to coat magnesium rims the high
temperature of oven can ignite and cant be extinguish so be warned.
Craig Hughes
color ur mags - Melbourne, Vic, Australia
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
