Platinum black electroplating
Q. I'm looking for information on platinum black and platinum black electroplating. I have been having trouble locating research articles and books pertaining to this topic.
Ron Kushner
- Sylmar, California, USA
Need platinum black thin film deposited into metal sponge
RFQ: I am looking for a source for plating a thin film of platinum black into the pores of a metal sponge.
Tony Iacovelli
director of R+D - Asheville, North Carolina, USA
Q. I am trying to do platinum black electroplating using ysi 3140 platinizing solution. But I get either clustered or non uniform platinum black coating. Can anybody suggest, how to do a uniform platinum black coating.
Ajay Vikram
alabama university - Montgomery, Alabama
Standard Methods for the Examination of Water and Wastewater
AWWA
or eBay or
A. There is a procedure for coating conductivity electrodes with platinum black in the "Conductivity" chapter of
<== "Standard Methods for the Examination of Water and Wastewater" that might be of help to you.
dave wichern
Dave Wichern
Q. I am experimenting with plating for neurological studies and am having trouble finding source of Platinum black on the web. Can anyone help?
Update: I have found suppliers but I still need information on how much PtBlk/liter to use when I plate a Pt electrode. I have read several papers, (Mareese, Feltham/Sriro, Mills, Desai, etc.), they all talk about the plating solution, (typically Cloroplatic acid and a lead compound), but none indicate how much Platinum Black they used.
Jerry Gregoire
engineer - Bozeman, Montana, USA
October 18, 2010
A. It depends on what you want to do? To plate platinum black on platinum? In that case you can use next solution and process (According to: G.Buchner:Metallfaerbung, Berlin 1922.): 300 mll water, 10 gm platinum chloride/0,08 gm lead acetate, 4-6 V, current density must be so strong that many gas bubbles forms, after 3-4 minutes poles must be reversed(+=-,-=+) and after 10 minutes black platinum must be formed. Hope it helps and good luck!
thumbs up signThanks for your response. One of my pitfalls was thinking that platinum black needed to be added to the bath rather than the Pt being reduced from the chloroplatic acid.
Jerry Gregoire
Electronics - Bozeman, Montana, USA
October 21, 2010
