Seeking cylindrical nickel anodes
Does anybody know where I can get cylindrical nickel anodes that are about 1/4 inch diameter and at least 8 inches length? Thank you.
warren s [last name deleted for privacy by Editor]
brklyn, New York
Check with all of the anode mfgs. Years ago, I bought anodes from McGean Rohco out of Cleveland.
If this is for aux. ID anodes, you might be able to get by with a 400 Ni rod. I do not recommend this for a primary anode.
Hi Warren,
You might also try your local supplier of copper buss bar. That is who we use. They usually will have to special order it and takes a little longer. If that doesn't work try getting some information from Inco Inc.. Their number should be in the Metal Finishing Guidebook & Directory. Be careful of the Nickel 400 as it has copper in it.
Rick Richardson, MSF
Dayton, Ohio
adv. Carter Alloys Company [a finishing.com supporting advertiser] may be able to help.
