Soldering nickel-plated battery tabs
Hi,
I am trying to connect 3 2Ah lithium polymer cells in series by soldering it onto a PCB.The connecting nickel tabs are 0.2mm thick by 7mm wide. Please advice how this can be done. Pre-soldered battery packs from Korea have even amount of solder on each tab, they don't look like they are hand welded.
Teck Kee Shih
Hobbyist - Kuala Lumpur, Malaysia
Hi Shih,
You need an experience person to do it aternatively you can use ultra sonic weld.
Thomas
Thomas Vun
- Kuala Lumpur
