Muriatic acid stains on stainless steel
Q. By mistake yesterday I splash with the mop a few drops of muriatic acid this on eBay or Amazon [affil links] solution (water diluted) on the freezer of a house we were repairing the grout, we didn't notice the accident until today that the owner of the house call us a let us know she have small yellow marks on the stainless steel door of the freezer. What can I use to remove those stains?
Andrew Costas
contractor - Bay Harbor Islands, Florida
A. Fine grain 00 steel wool this on eBay or Amazon [affil links] , work with the grain/finish. The stains shouldn't be too deep (you can also use brillo pad this on eBay or Amazon [affil links] ).
Marc Banks
Blacksmith - Elizabeth City, North Carolina, USA
A. DO NOT use steel wool or Brillo Pad unless you want to have a rust problem.Use only a NON iron containing material like Scotchbrite(TM) or fine grain emery paper or the like.
lee kremer
lee kremer sig
Lee Kremer
Stellar Solutions, Inc.
McHenry, Illinois
stellar solutions banner
Q. We are remodeling our home and have just discovered what we think are tiny acid stains in our brand new sink. They are numerous, tiny and appear to be pitting the surface and have not come out with the usual commercial products available.
What can you suggest as a next step?
Kate McCaw
- Summerville, South Carolina
A. I've had experience removing muriatic acid stains from stainless steel. A metal finishing specialist once told me to use Barkeepers Friend this on eBay or Amazon [affil links] , a cleanser readily available in stores, with a cloth or sponge. It's non-invasive and is the best first step. I was amazed how well it works with a little elbow grease and a few applications. I've used it a couple times without the need for abrasive pads like emery cloth or sandpaper. These would only be second options as they can change the grain of the finish. Spread the word. It's a little known secret that works.
Tom Black
Tile Contractor - Woodinville, Washington, USA
March 18, 2008
Q. I sprayed my gas stove with Mr Muscle kitchen Cleaner, became busy with some other work, went out on errands and forgot all about it till I returned home late at night! I was shocked when I went to switch on the gas to find it all stained. I tried CIF, more Mr Muscle, plain soap and water - and even ash! nothing worked - the stains make the stove look so dirty - please help someone and tell me how to get the shine back!
tonee Patil
Distressed Housewife! - Bangalore, Karnataka, India
August 30, 2010
Q. Stainless steel kick plates on mahogany-colored wooden doors look impressive in any business setting, until floor finish or stripper from adjoining CVT or seamless floor covering is accidentally splashed onto the bottom of kick plate. Cleaning crew tries Windex Commercial Line this on eBay or Amazon [affil links] , which has ammonia, and leaves all kick plate shining except for the bottom that is stained. Keep working on the panel and eventually it takes on brownish streaks with or against the grain. Seemingly the more the panel is wiped, the worse it gets. Brownish scares me. Makes me wonder if it is starting to rust. Had a similar problem with grab-bars in hospital restrooms. Everything had to sprayed or wiped with a germicidal cleaner/disinfectant for infection control. The product does a good job killing germs, but it also kills the luster of the stainless steel grab-bars. First little brown spots appear. Is it possible that stainless steel is not always stainless, or can those brownish stains be worked out? I saw an empty Mineral Shock bottle sitting around somewhere. Would that item possibly be on of the suggested cures, and worthy of purchase?
Don Corbin
Building Maintenance - Albany, Georgia
April 22, 2011
Adv.For all those questions regarding acid staining damage on stainless steel surface, Scratch-B-Gone is the proven solution for the discoloration and rust stains. Makes fast resolve to this unsightly problem while protecting the surface from re-staining.
Barry Feinman
BarrysRestoreItAll
Carlsbad, California
barrysrestoreitall
Q. Had some grout cleaner splash on a customer's refrigerator! It does not hold a magnet but I'm pretty sure it's 'print proof'. Is your product safe to use on a smudge proof stainless steel?
Antonio Durazzo
Contractor - Lakewood ["Colorado?", asks the editor living 5 mi from Lakewood, NJ]
July 30, 2021
Did maids or someone else cause stainless appliance to blacken?
Q. I was wondering what chemical reaction would cause a stainless steel oven to turn black in areas on the outside? The owner is blaming my company, but we don't carry acidic chemicals in our supply. I do know that the painters had been there as well and had a pump sprayer with them (most likely of muriatic acid but I am unsure). It looks as though something was sprayed on it and dripped down between the knobs. It is black almost as if it were burnt.
Would bleach cause that, or something with bleach in it? The owner claims it turned black very quickly. From what I have read, bleach would have to be used over and over or left on for a long period of time. We were only there once, and whatever the young lady used was wiped off right away.
Susan Ellis
Janitorial - Northport, Alabama USA
August 6, 2014
A. Hi Susan. A photo would help, and if the owner is not willing to let you take a photograph, I don't think you should be willing to offer anything when you don't have reasonable grounds to suspect an error on your own part. Looking at the "trails" may help indicate their origin. If the trails are only below the knobs, it's hard to blame painters, tilers, or anyone else but you or the homeowner or some other janitorial service.
Bleach is bad for stainless; the stronger it is, the worse. Some other cleaners like "Zap" and "CLR" and "Lime Away" are also probably bad for stainless. Good luck.Regards,
July 2014
Q. The blackening starts at the top ledge of the oven above the knobs, where some people set trinkets or salt and pepper shakers. The trails are wavy and run down between the knobs.
From what I have seen the "stainless" might be a different type of metal.
The blackening is similar to what happens to aluminum when it comes in contact with muriatic acid. As you can kind of see in this video: https://www.youtube.com/watch?feature=player_detailpage&v=ts0XRbBlF5Q
I'm not sure if the owner will let us take pictures or not, he is pretty irate. He said he was going to send before and after photos, but has not provided those. The property was kept unlocked for several days so that repairmen, painters and cleaners could come in.
Susan Ellis [returning]
August 6, 2014
A. Susan,
Bleach is bad for stainless, muriatic acid is much worse. Any etching or staining that has a distinct splash or drip appearance generally is exactly that, the result of a strongly corrosive chemical getting onto the stainless surface.
Stainless that is regularly cleaned with bleach will suffer eventually, but the corrosion will be more evenly distributed. The other common thing is muriatic acid floor cleaners giving off fumes that attack the lower portions of stainless steel appliances.
ray kremer
Ray Kremer
McHenry, Illinois
August 25, 2014
Q. I'LL BE QUICK WITH MY QUESTION, DOES MURIATIC ACID WORK AS A CLEANING PRETREATMENT FOR STAINLESS STEEL PARTS? FROM WHAT I READ, IS NOT RECOMMENDED. SO WHAT CAN YOU GUYS RECOMMEND? REGARDS, THANK YOU IN ADVANCE.
HASSAN TELLO
- ANAHEIM CALIFORNIA USA
January 7, 2016
A. Hi Hassan. Is this one small part for personal use, or is it a factory run? Whether a pretreatment is good depends on the final finish that you are pretreating for: will you be painting, plating, or powder coating it, or passivating it please).
What kind of "cleaning" does it need? Acids are not used for "cleaning" anyway, alkalis and detergents are used for that. Get back to us please. Thanks.
Readers: You never do anyone a favor by being "quick with your question" because abstract questions can almost never be answered properly. All a 'quick question' achieves is it requires someone else to ask all the who, what, when, where, why questions -- and most readers will just ignore the question instead :-(
January 2016
Some welders use muriatic acid to remove the blue oxidation from SS that turned blue near weldments. If done, it would require a minimum of a rinse and a weak neutralization and another rinse. I am not in love with it and it should not be done on high dollar parts without follow-on treatments like passivation.
January 8, 2016
Hassan,
No, no, no, never, never. Muriatic (hydrochloric) acid is the deathly enemy of stainless steel.
For pickling, use nitric/HF.
For passivation, use nitric or citric.
For general cleaning/degreasing use a detergent or alkaline cleaner depending on the nature and severity of the surface contamination.
For adhesion of powder coat, adhesives, etc., sand or bead blasting is probably best.
Okay, there is one time where you would use HCl. If you are plating on stainless, normally a woods nickel strike or something similar is needed beforehand.
ray kremer
Ray Kremer
McHenry, Illinois
Q. I splashed muriatic acid on a stainless steel fronted dishwasher and stove and there are now black spots along the bottom six or eight inches of the appliances. how can I remove these spots?
Debra B Choate
- Nacogdoches,Texas
April 3, 2016
Q. Help I cleaned my mother-in-law's stainless steel sink with toilet bowl cleaner, and where the cleaner was you can see marks. Can someone please help me fix this? I don't want her to come home and see this ugh. Thank you so much.
Anna McCarthy
- Boynton beach Florida usa
March 28, 2017
A. Try cleaning the sink with Brillo pads and water. Go slow and easy until you blend in the discolored areas.
April 12, 2017
A. Anna,
There are some kits for this sort of thing available commercially. The one I always remember off the top of my head is Scratch-B-Gone [a finishing.com supporting advertiser] , but I recall seeing one a while back under one of the 3M brand names too.
ray kremer
Ray Kremer
McHenry, Illinois
Q. A pool chlorine tablet was set on the divider between my new stainless steel sink. It now appears the stainless steel has been corroded. Is there any way to repair this?
Marian Foster
- Carthage [Texas]
May 5, 2017
Q. How to remove black stains in my stainless steel sink? I've put some muriatic acid to remove the yellow stains in tiles; I put the chemical in stainless steel sink. After a few minutes the stainless steel sink absorbed dark stain and it is very difficult to remove. Please help.
mike ayolp
- Tagum city, Philipines
November 16, 2017
November 2017
thumbs up sign Hi cousin Mike. Have you tried any of the solutions already proposed above? Our helpful responders probably dislike simply repeating themselves over-&-over; so please tell us if you tried any of the proposed solutions and how it went :-)
Thanks and Regards,
thumbs up sign I'm a believer. My GOSH! I accidentally spilled Muriatic acid onto our stainless steel kitchen sink. It left large dark brown stains. I was sick to my stomach... enter Barkeepers Friend . HOLY MOLY, it cleaned it all away. I couldn't believe my eyes. I read about it online and glad I found the recommendation. NO JOKE, this stuff is amazing.,
K Andronica
- Charlotte, North Carolina
February 24, 2018
Q. I was stripping my kitchen floor, it came out nice, but I then realized that the stripper splashed on my stainless steel refrigerator. It seems like it stripped the first layer of the stainless steel. Can someone help me make my refrigerator looking like new again. It's only a year old.
Edward Davis
Retired - San Antonio, Texas USA
October 31, 2019
