Activation after Nickel
We do perform electroless Nickel (sulfamate) over chips and then Tin/Lead(60/40), what would be the recommended activation process in between?
Alvaro Quesada
plating shop - Costa Rica
I have no knowledge of an electroless nickel chemistry using nickel sulfamate. This salt is commonly used for electrolytic deposition. In any case, activation is normally done in a Woods strike (high chloride high free acid nickel bath).
Guillermo Marrufo
Monterrey, NL, Mexico
I wonder if an alkaline cleaner wouldnt do the same also.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
An alkaline cleaner will do the same activation as a nickel strike solution only if it is a cyanide alkaline solution.
sara michaeli
sara michaeli signature
Sara Michaeli
Tel-Aviv-Yafo, Israel
