Help with percent composition
Ok- I understand how to do percent composition except:
If you have CuSO4 . 5H2O, do you distribute the 5 to the H2 and get 10 H atoms and then distribute it to the O and get 5 O atoms?
Nicole S.
student - Falls Church, Virginia
Technically, the dot 5H2O means that you have 5 molecules of water mechanically attached (water of hydration) to the copper sulphate. For most calculations, you would consider it as water rather than atoms of H and O. You do consider it in the weight when you are trying to weigh out an amount of the hydrated material to get a given amount of the copper or the copper sulphate [on eBay or Amazon (adv.)]or the sulphate.
