Non-wetting defect on NiPdAu plating
We are encountering "Non-wetting" defects for all IC's Having Nickel Palladium Gold (Lead Free) plating. The solder paste the we are using was still SnPb (WATER SOLUBLE). Crack plating on the bend area of the IC leads was observed leading to exposed copper. We just want to know the criteria of the crack plating and its effect to solderability.
Joel Macalindong
Integrated Microelectronics - Sta Rosa, Laguna, Philippines
The only thing to prevent cracking on plated portion after bending is to do forming first before plating. It is possible but need to do a lot of modification on the process. Try to do baking before forming at 150 °C at 1 hour. We tried it and it helps a bit compare than no baking.
Irvy Cane Boltron
Dear All,
I'm from Engineering group facing intermittent soldering on TSSOP lead where visual inspection shown incomplete wetting or due to exposed copper at lead cutting edge. Would like to understand the process flow of Semiconductor IC where after plating process, do they need to perform cleaning or not. From our knowledge, there is cleaning process to removed any chemical/oil to avoid solderability issue to the component lead. Will this may lead to defect shown below.
34144-1 34144-2 34144-3 34144-4
Hashim Mahmud
Engineer - Penang, Malaysia
