Does hot dip galvanizing work for stainless steel?
Q. Does hot dip galvanizing stick to stainless steel? We have some parts that are a mixture of plain and stainless steel. I have heard that galvanizing will peel off of stainless, if it sticks at all, but I am not sure if there is any validity to this statement.
If hot dip galvanizing does not stick, can anyone recommend a process to coat sections of welded plain and stainless? The product is made from 3" schedule 40 pipe, and has elbows and bends. There are also pieces of plain steel (brackets, clips, etc.) that are welded to this 3" schedule 40 pipe. Because water runs through it, the plain steel sections must be coated.
- Englewood, Colorado, USA
A. Carey,
One does not weld plain steel (I assume you mean mild steel) galvanized or not to stainless steel. Galvanic corrosion will be the result. If you need to fix mild steel parts onto stainless parts, go the mechanical way: clamping, bolting etc. If the parts are exposed to a corrosive environment (outdoors, high humidity, etc.) be sure to avoid direct contact between the two materials. Separate them using non conductive (i.e., plastic) washers.
Remmelt Bosklopper
- Enschede, The Netherlands
Q. Remmelt,
I was always told that if two dissimilar metals are to suffer galvanic corrosion, there must be an electrolytic path between them. By galvanizing the welded assembly, I would then be sealing the unit and removing the path of travel for the metal ions. Is this incorrect?
A. Hi Carey. I would agree with that. If the whole surface is coated with zinc, there is no galvanic action.
Although I don't know the feasibility of galvanizing stainless steel, lots of parts are made with dissimilar metals as long as the whole surface is coated with the same metal. Many bright decorative things like slot machines are made by brazing steel pieces together then nickel-chrome plating them so the different electrochemical potentials of brass and steel do not cause a galvanic problem. The weldment/assembly can be electroplated for corrosion resistance.
Q. To clarify a little ... I am using 304 SS, and this should have enough nickel to allow for galvanizing. Our vendor is having to dip the piece twice. The first coat covers the plain steel and puts a splotchy coat on the stainless. They let the part cool enough to handle, then dip it back into the zinc. On this second coat, the zinc sticks to the stainless. Are there variables in their tank that I should be asking about? This doesn't make much sense to me.
A. The hot dip galvanizing may not stick to the stainless steel unless the zinc penetrates the passive oxide film on the SS to form a metallurgical bond.
HD galvanizing is typically not a good idea for 300 series SS because the zinc will preferentially penetrate the grain boundaries of the SS. (The same problem can occur from welding SS to galvanized steel.) If these assemblies are subjected to external forces, the mechanical properties, especially fatigue behavior, may not be what is expected. If these assemblies are used at elevated temperatures, catastrophic failure from solid or liquid metal embrittlement is possible.
Galvanic corrosion should not be problem if the whole assembly is coated. The zinc will be sacrificial for both the stainless and the plain steel. In most environments, galvanic corrosion of steel in contact with stainless is not a big problem, since the stainless surface should be passive and not available to participate in the corrosion process. The mixed weld area could be different story.
Hope this helps.
Larry Hanke
Minneapolis, Minnesota
Pickling/galvanizing 304 stainless steel
Q. What are the best parameters to pickle 304 stainless (e.g., which acids, temperatures, additives)?
What are the best parameters to hot dip galvanize 304 stainless (fluxes, temperatures, additives)?
June 2, 2015
A. Thomas,
Refer to ASTM A380
for pickling mixtures. These are typically nitric or nitric/hydrofluoric. The exact parameters necessary would depend on the specifics of your parts.
And remember, pickling is for descaling. If what you are after is corrosion resistance, that is passivation. See ASTM A967.
Stainless isn't typically ever galvanized, though the responses above do imply that it's possible if for some reason you really really want to. I always say though, if you are going to put a coating on stainless and rely on that for corrosion protection, why use stainless in the first place?
Ray Kremer
Stellar Solutions, Inc.
McHenry, Illinois
Thanks for the very helpful pickling & passivation specs and the suggestions, Ray!
But for readers from other disciplines who therefore might not know Dr. Cook, he is arguably the world's best known & most respected galvanizing expert. I'm reading his quest for details as mostly skepticism about the practicality of galvanizing stainless steel rather than activating it :-)
A. Overpickle in hydrochloric for 3 days and turn the kettle down to 820 °F. Aircool - no water quench. It will galv.
D. S. W.- Houston, Texas
July 7, 2022
Ed. note: Welcome! Feel free to visit anonymously! But our 35-year legacy of warm aloha is incompatible with anonymity; please only post with your full real name.
Q. This has been great information. I had the bow roller assembly on my boat trailer modified to accept a new winch.
At that time I wanted to add a pivoting dual bow roller assembly.
TO be helpful, the fabricator WELDED two stainless bow roller holders onto a custom pivot bracket then WELDED the pivot bracket (304 stainless) to the Mild steel vertical post to which the winch is mounted.
SO basically the bow of the boat, when loaded onto the trailer, comes to stop on a pivoting dual bow roller assembly made of 304 stainless that was WELDED to the mild steel vertical post on the trailer (to which the winch is also mounted)
I cannot galvanize part of the assembly. Can I galvanize the 304 stainless that has been welded to mild steel?
WJC - Kuwait City Kuwait
July 14, 2016
Q. Hello! Regarding mixed-metal problems, I bought a used tow-bar online from a vehicle dismantler in Swansea. The tow-bar was rather rusty so eventually I got around to dismantling it and cleaning it up. Someone had made the mistake of fitting a large stainless steel bumper protector plate but it has caused severe corrosion on the mild steel. (probably a Chinese Rustqwik brand made from shredded cars) Once the affected parts have been shot-blasted a few weld beads can be added to restore the strength (the same dodge is used on steel boats that have had bronze seacocks fitted)
The stainless plate is still going to be the problem. Trying to insulate it when it is clamped-up with two M16 (5/8") bolts will be impossible but what if it was shot-blasted and painted?
I live in an area that has high humidity and severe marine corrosion.
- Bude Cornwall England
July 25, 2016
A. Hi Folks. I think, where practical, I would use zinc-rich cold galvanizing compound on any steel parts, and also paint any stainless parts to reduce the galvanic incompatibility.
August 2016
Q. Dear Sir,
I would like to know can we do Hot dip galvanising to the Junction boxes made out of SS 304 grade? Is there any chance of Galvanic corrosion ?
With warm regards,
- Bangalore India
July 28, 2016
A. Hi. As long as only one surface remains exposed (the galvanizing in this case), you can't have galvanic accelerated corrosion. But this page has been on the web for over a decade, getting 200 or more visits per month, with nobody yet claiming that they've seen galvanizing of stainless steel truly working properly, so I remain dubious :-)
July 2016
A. I agree. It isn't possible to galvanize stainless steels. Nor is it sensible to do so!
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
August 4, 2016
Galvanizing a weldment of steel and stainless steel
Q. We have 316 SS parts welded to a carbon steel structure going into offshore environment. The items are to be Galvanised. Firstly the items are pre steel grit blasted, galvanised then sweep blasted using a non-metallic abrasive before receiving an epoxy coating system with a polyurethane topcoat. My question is the pre steel grit blasting of the small welded SS parts would contaminate the SS, would this still be a problem even after the full coating system is applied?
Ian Dawson- Liverpool, UK
May 31, 2019
A. Hello Mr Ian,
On the contrary, my personal experience is that the blasting on SS wakes up the surface and improves adhesion.
Khozem Vahaanwala
Saify Ind
Bengaluru, India
June 15, 2019
A. Ian,
Yes, steel blasting of stainless will contaminate it (as opposed to blasting with stainless shot or glass bead), but since you're putting multiple coatings over the top of it, it doesn't really matter much at that point.
Which also raises the question, why bother paying the extra money for stainless steel in the first place?
Ray Kremer
McHenry, Illinois
June 18, 2019
Q. I have hot dip zinc galvanized parts consisting of 304SS welded to mild steel. The finish looks fine. Should I be concerned about mechanical integrity of the parts?
C.R. Stephenson- Raleigh, North Carolina USA
January 20, 2020
A. Hi C.R.,
Can you tell us what the parts are? Some things we wouldn't dream of doing on aerospace parts may be rather routinely done on low pressure vats, simple linkages, and farm equipment. Mr. Hanke warns of the zinc weakening the stainless against fatigue loading at high temperatures. Mr. Crowley says 304 stainless can't be gainfully galvanized and Dr. Cook seems to me to be expressing skepticism.
Are you certain that the parts are 304SS, and that the coating is applied by hot-dipping rather than electroplating or another technology? Some earlier posters have told us that the reason they ended up with a mixed-metal weldment was because they added stainless components to a galvanized boat trailer. Why are your parts mixed metal? Thanks.
January 2020
