Cleaning dirty gold taps
I've recently moved into a property which has gold taps in it. There is nothing wrong with the taps there just dirty (tarnished) how can I clean them up? have you got any recommendations what I could use.
Many thanks,
private home - Leicester, Leicestershire, England
A normal metal polish will work fine, look for one that does not use heavy abrasives. I suggest Nevr-Dull [affil links], just be sure to clean it off afterward with a dry cloth.
Marc Banks- Elizabeth City, North Carolina
If your taps are brass or bronze You can use 5% citric acid [on eBay or Amazon (adv.)] solution (or 50 gm citric acid /1 lit water/+ some ammonia [on eBay or Amazon (adv.)], pH must be 9)! vinegar [in bulk on eBay or Amazon (adv.)] mixed with some salt can help you too. Rinse well! Good luck!
Do not use vinegar to clean gold plated taps! I used this and it tarnished them so badly they will have to be replaced.
John Sherburn- Bury, St Edmunds
