Letter 33081
How to blacken Nickel electroforms
We electroform pure nickel in polymer molds. I am looking for a Ni surface treatment that can be used to significantly "blacken" the nickel surface. We can not use plated Ni Black as we have other metals in our system (Cu in particular) that we do not wish to deposit on. Does anyone know of a chemical or electrochemical surface treatment that can blacken the Ni by a conversion process?
Thanks in advance for your advice.
Raffi Garabedian
- Monrovia, Ca, USA
Dip in 50% nitric acid
- Spartanburg, SC, USA
Black patina for nickel:
       o,5 gm potassium sulfocyanide
       5 ccm sulphuric acid
       25 ccm sodium peroxide
        Cold immersion (15 C,15 minutes)
       Use only fresh solution !
- Zagreb ,Croatia
Try 0.5g/l potassium thiocyanate with 25ml/l of 10% sulphuric acid and 25 ml/l of 20 Vol hydrogen peroxide. Use at room temp for 2-6 minutes.
R&D practical scientist - UK
I'd like to thank both the administrator of this web site and the kind responders for their suggestions.
Raffi Garabedian
- CA, USA
Ed. note: You are certainly welcome, Raffi, but the very best way to thank the kind responders is to let us all know how things worked out after you try it.
Black for nickel:
       0,5 gm potassium thiocyanate
       25 ccm hydrogen peroxide
       Cold immersion(15 C,15 minutes)
       Use only fresh solution!Good luck!
- Zagreb, Croatia
Dear Reader, please --
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
