Letter 33078
Copper stripper
I am looking for chemical or chemicals to strip 1 microns of copper plating from a nickel alloy material (Ni(70%), C(0.05),Si (0.15%), Mo (4.0%)) without affecting or etching the surface. I do not wish to use cyanide or a cyanide based chemical. Please recommend me the best way to solve this problem.
Fong
Fong Lean Guik
Immersion in ammonium hydroxide (ammonia water) will dissolve copper in short time and will not affect the nickel alloy. Odor is very strong and irritant and disposal must be done in accordance with your local laws.
Guillermo Marrufo
Monterrey, NL, Mexico
Mr. Marrufo,
Seems like it doesn't strip the copper plating even using 28% concentrated ammonia water (without adding addition water). Any other ways to strip copper on nickel alloy without using cyanide.
Fong Lean Guik
First of two simultaneous responses -- ++++
Try adding about 2-4% of 35% hydrogen peroxide.
- Spartanburg, SC, USA
Second of two simultaneous responses -- ++++
One micron of copper should be no problem to ammonia (should remove it in less than one hour). If it is not working then it is not copper or has something else on top of it. Another possibility is to use anodic treatment part is (+) stainless steel is (-), 6 volts and 30% alkaly in water (sodium or potassium hydroxide) but again this may not work if ammonium didn´t.
Guillermo Marrufo
You can use 150 gm sodium sulphide/15 gm sulphur/1 lit water solution(20 C temp.)!
- Zagreb, Croatia
Sodium or Ammonium persulfate will work very well.
Lee Kremer
Stellar Solutions, Inc.
Algonquin, IL, USA
Dear Reader, please --
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
