Letter 33045
Safe removal of clear coat from brass
[Mississippi]
I am an contractor working on brass stanchions which are used to
section off areas of high traffic. the total number of stanchions is
200. The Stanchions have an clear coat on them I need to remove the
clear coat without damaging the brass so that the brass can be
polished and clear coat reapplied I do not know what method to go
with please help.
Derrick Fudge
specialty coating - Biloxi, Mississippi, United States
You can use any solvent based paint stripper!
- Zagreb , Croatia
You need to know what the clearcoat is. There are several
possibilities, and each requires a different solvent. The solvents of
choice are all flammable and some are mildly toxic. This is not a job
to give an untrained worker a bucket of solvent and a rag.
Have you considered using dry ice blast cleaning. Clear coat can
be removed without damaging the surface of the brass and you will
have no clean up.
James Becker
- Cleveland, Ohio, USA
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
