Steel and aluminum roof combo
I'm putting a steel roof on a new addition to my house. The older roof that I'm going to run up on, is an aluminum aluma-lock shingle. Will I have a problem in the future with corrosion? and if so, what can I do to avoid this problem? Anything you can tell me would be greatly appreciated.
Scott Morrow
homeowner - Evanston, Wyoming, USA
If you can keep the steel from actually touching the aluminum there will be no problem. Galvanic corrosion requires a metal to metal connection.
