How to recognize passivation frosting?
Q. Can you help my understanding by some pics of accept and reject passivated steel surfaces?
Sony KNV- Hyderabad India
April 7, 2021
Q. Passivation specs require the parts to show no "frosting". How can someone distinguish unacceptable surface frosting due to poor passivation from a surface given a media finish opeartion prior to passivation that leaves a matte finish another person might call "frosted"?
Fred Coneaerospace manufacturing - West Palm Beach, Florida, USA
A. "No frosting" is referring to an etching of the material, typically from contaminants in the acid -- chloride comes to mind. ferric chloride [on eBay or Amazon (adv.)] from using tap water and the dissolved iron in a well-used bath will definitely do it. Trust me, you will know it when you see it. It literally looks like frost, which is quite different from a blasted surface.
James Watts- Navarre, Florida
