Acid zinc plating Anodes Q&A
May 23, 2022
Q. Hi there,
Our acid zinc plating bath got like 3 months running; everything is okay but a question surged because we noticed that our zinc anodes change their surface aspect, turning into a blackish color.
discolored zinc anode
So we are wondering why is it happening and does it affect directly to our plating parts?
Jorge Lim
- Sinaloa, Mexico
A. Hi Jorge. Not necessarily because of the color, but as general QA assurance you should probably (at least once) check whether your anodes have cadmium in them unless you have enormous confidence in your anode supplier.
Thread 56987 is about that subject.
pic of Ted Mooney
May 2022
I have an ammonium chloride/Potassium chloride zinc plating bath and my metal is continuously climbing up. I am keeping my chlorides below 14 O/G and pH is about 6.0 Now, I have some options of either putting some insoluble anodes in or pulling out some existing anodes (without disturbing anode to cathode ratio).
I would like to see some debate at this wonderful platform about following things as different experts are giving me different advise.
Q1. Is pulling out zinc anode baskets is a good option. An expert has taught us not to do so as it may increase more metal as less anodes get more current density and will eventually throw more metal in the bath? (wait a minute, does not less anode area means less metal in the bath)
Q2. Which insoluble anodes are good for the above kind of bath.
Q3. Hey, interesting question: What is the best way of calculating surface area of an anode filled with zinc balls. Is this just one rectangular side area of the basket or is it the sum of one rectangular side and total area of all the individual zinc balls (and I hope in each case we are calculating one rectangular side of the basket only as the other side is facing the tank wall)
Let us do a little debate here. I need some help. I know the best way is to run my own tests and find out, but you may have some prior experience which might benefit us. Lets share our experiments here.
Hemant Kumar
Hemant Kumar
- Florida, USA
"Electroplating Engineering Handbook"
by Larry Durney
EEHcover
or eBay or
Hi, Hemant.
A3. Imagine a baseball-size & shape sponge. How does it's "surface area" compare to the surface area of a baseball? If you tried to determine it by gluing as many ping pong balls to the surface of each as possible, the surface area would be exactly the same. If you tried gluing bb's to them, you could probably glue maybe twice as many to the sponge because some bb's fall into the holes in the sponge. You could perhaps glue 10x more grains of sand to a sponge than to a baseball, and say 100x more grains of flower. So is the surface area of the sponge the same as a baseball or 100 times greater or somewhere in between?
Similarly, what is the seating capacity of a room? For a royal concert, the capacity of a large sofa and its footstools is one couple. For a teen party, that sofa and it's footstools may seat 7 or more :-)
Sometimes it's best to calculate the capacity of a room by looking at the area of the doorways that lead into it rather than the surface area it's furnishings. Everybody has to pass through those doors. Likewise the current to an anode has to pass through the "door" that is the L x W x D of the anode basket. That's what I would call the surface area of the anode.
Although less current flows to the back of a basket, personally I use the surface area of the whole basket; if you were using stick anodes you would calculate based on the surface area of the whole stick anode; and certainly, the surface area of basketed anodes is not less than the surface area of stick anodes of the same size as the basket.
thumbs up signTed Mooney
Wonderful, and that's the way I always thought. Previously I was calculating my anode to cathode ratio based on your logic. And everything was 2:1 (anode to cathode).
But now I have like 250 square feet at cathode whereas my total Anode basket area will be 25 square feet only. So I am down to 1:10 instead of 2:1 (anode:Cathode).
Hemant Kumar
Hemant Kumar
- Florida, USA
A. Prior to changing to alkaline zinc solutions about 7/8 years ago we operated acid zinc solutions and found that increasing the total chloride concentration to about 200-210 grams per liter (about 34 oz/US gall I believe) had the effect of preventing the zinc content rising. This was based on advice from a rep who had seen this practice work in other plants. We were skeptical but followed the advice anyway. The theory behind it being that the solution reaches a saturation point where it won't accept any more zinc into solution. That may or may not be the reason it works, but once we tried it we ran for several years without any problems with rising zinc concentrations. I would certainly recommend increasing the chloride concentration and would advise against putting insoluble anodes into the solution.
Dougie Lightfoot
- Fife, Scotland
Wow, keep one constituent so high that other does not have chance to get in. To do this, I might need lots of lab work to make sure the process is robust. But wondering, would it not affect any after plating characteristics, any chromate, peeling off etc. All these parts go to bake and I hope there is no problem with Chloride level so high. Also what other platers think about pulling out anodes options. Any experiences to share!
Hemant Kumar
Hemant Kumar
- Florida, USA
A. Hemant,
Technically Mr.Dougie's opinion has a valued point as long it's possible to maintain the metal to chloride concentration in 1:4.4 ratio. A few brighteners have the property of oiling out when the chloride content goes above 150 g/l.Have to watch that! And moreover reasonably concentrated baths are high efficiency baths.
I also have a similar predicament and I am trying to avoid removing baskets or diluting the solution, either its cumbersome or wasteful.
One article says that use of magnesium or aluminium alloy will prevent zinc build up but till now I am aware of anyone using those anodes in industry.
Venkat Raja
- Kitchener, Ontario, Canada
thumbs up signBuildup of zinc concentration in acid zinc plating has been a perennial issue ever since its invention. If magnesium or aluminum anodes can prevent it, I for one would like to hear more. Thanks for bringing it up!
A. We didn't bake after plating but I wouldn't think the deposit characteristics would alter so much that it would be an issue.We did occasionally powdercoat some plated components and these were processed with no problems. The pH needed to be maintained around 5.5 to prevent roughness but that may have been more to do with the additive chemistry than the chloride concentration.
Dougie Lightfoot
- Fife, Scotland
A. Subsequently you can try to reduce the anode efficiency with a combination of soluble and insoluble anodes. This will help you maintain a balance of metal getting into the solution.
The insoluble anode can be ferrite or RuO2 coated anodes or other material having a low Oxygen or Chlorine over potential. By using this you will enhance other reactions in the system and subsequently reduce the Zinc dissolution. But take a caution to make sure your brighteners or organics in the system doesn't break down due to oxidation (evolution of chlorine and oxygen).
Good luck...
Karthik Thambidurai
electronic components - Norwood, Massachusetts
