Letter 32095
Quality of rinse water and phosphate
coating weight for powder coating
We are experiencing corrosion problem on powder coated parts which
are exported. Powder coating is carried out after 7 tank hot
phosphating. The coating weight being given is 4.3g.sq.m. While
trying to solve the problem we need the following clarifications:
1.The quality of water/or the specification of the rinse water.
2.The ideal coating weight to be maintained.
Kindly help us with the clarifications sought at your earliest
convenience.
R.V.Ramanee
- Bangalore, Karnataka, India
If the technical leaflet of the phosphating chemistry does not
specify these details, you need a more competent chemistry supplier
first.
Secondly there is no such thing as a 7 tank process!!
7 tanks in a row do not suffice/constitute a decent phosphating
processs, they are ok to swear by, but you will not ensure proper
phosphating by dipping parts through in 7 cocktails.
Khozema
Vahanwala
Automaxx
If you are using 7 tank hot process,It means you are using
di-cationic dip phosphating.Use tricationic phosphating ,It has
better advantage . I want to ask you one thing that what is the
geometry of your components.Are you dealing with box type of
components?
Manish Dhyani
- New Delhi
You did not state the type of phosphating you were doing, iron or
zinc. With a seven stage process the superior zinc phosphate system
can be used.
Stage one cleaner, make sure all the mill oil and soils are
removed. stage two rinse direct from your water source, as long as it
is reasonably clean. The most important thing here is getting all the
cleaner off by keeping the cleaner contamination of the rinse water
low (overflowing), sufficient heat and volume to get good rinsing and
enough pressure to get good impingement 1.75 kg/cm^2. Zinc phosphate
forms by precipitation on pH change which can result from cleaner
residue. Stage three phosphate application ideally 2-4 g/M^2. Stage
four rinse with reasonably clean water to remove reaction salts.
Again you need to keep the contamination level low. Salts Left on
will cause build up of osmotic pressure under the paint film causing
blistering in the field over time. Stage five, chrome rinse sealer or
some other non-chrome substitute. Stage six DI water rinse with a
conductivity of 10 mho's or less. Since you have seven stages a
second cleaner stage would be most effective with a titanium
phosphate application halo on the last set of sprays.
Use statistical process control (individuals moving range) for
controlling all the significant characteristics and make sure plugged
sprays are promptly fixed. Canister bag filters on the rinses will
help immensely.
Ronald Zeeman
Coil Coating - Brampton, ON, Canada
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
