Letter 32092
Plating life problem--failing in Salt Spray
We are facing the plating Life Problem. The Plating Specification is as follows.- zinc + trivalent chromate clear , - coat thk : 4-5 microns thk - 48 hrs of salt spray test for white rust.
The Salt Spray test is Failing. I want Exact process To be followed with all setting parameters & details of Chemicals used. This is very important.
Venkatesh Purohit
Plating Shop - Pune, Maharashtra, India
It is important to you but not really important to the readers, Vyankatesh :-)
For that reason, you need to put far more effort into it than you expect a reader to put into it--yet you've spent mere seconds on your posting and want an answer that would take a minimum of several hours of work :-(
Contact a manufacturer or distributor of plating chemicals and ask them to come in and work with you please. Good luck.
finishing.com
Brick, New Jersey
Zinc plating with trivalent chromate sst life 96 hours possible. Chennai based manufacturing of plating chemical already marketing this product.refer.
P. Gurumoorthi
    electroplating process chemicals
Chennai, Tamilnadu, India
Mr Purohit
The specs you have listed are entirely possible indigenously, that is within India.. You need to connect with a qualified supplier / provider of Plating chemicals where these issues are resolved in an appropriate manner.
Asif Nurie
Atlanta Global Limited
New Delhi, India
Dear Reader, please --
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
