Letter 32075
Golf head nickel chrome plating corrosion
We are trouble shooting some inconsistent nickel chrome plating
corrosion results on a 1025 low carbon steel golf club head. The
interior deep sharp corners get inconsistent plating coverage, and
the 48 hour salt spray tests are varying.
Are there any recommendations for pre or post plating operations
which may improve?
Ever passivate a plated part in case there is some residual free
iron?
It is a Trivalent chrome process.
Mike Peters
Manufacturer - Vista, California, USA
You should take a look at racking to see if a different racking
method will produce better plate distribution in the low current
density corners. It may be necessary to increase overall nickel
thickness in order to get a thick enough nickel deposit in the low CD
ares to pass salt spray. If you are using single layer bright nickel,
a change to duplex nickel will improve salt spray performance. Any of
the major suppliers of nickel plating processes can help you with
that.
Jeffrey Holmes,
CEF
- Spartanburg, SC, USA
I'm suprised you consider trivalent durable enough for golf clubs.
I've been turning this type of work away.
Am I missing something?
Steve Clark
polishing and plating - Belfast, Maine
I have over 25 years of experience manufacturing golf clubs and
additional experience working with different Companies plating golf
clubs in California.
The problem described is a common problem in plating golf clubs.
The best feasable solution is to plate duplex nickel. The corrigation
lines and stamps are the typical areas of corrosion failures. This is
due to the extreme LCD areas and geometry involved. Rack positioning
will not resolve the problem. Conforming auxilliary anodes might help
but will be very costly.
You should be able to increase the salt hours by 2 to 3 times by
using duplex nickel.
J. Bruce Anderson
- McAllen, TX
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
