Letter 32052
Non Conductive Coating
Hello
I have a need to coat a clip used as a fastener. The clip is 304 SS.
Please reply if you have a product or process that will help me achieve the following
This is for a very high volume automotive application and will need to be Validated as such.
The requirements for the coating are:
1) Electrically non conductive
2) The coating should be somewhat flexible (the clip has action)
3) The coating should be as thin as possible
4) The coating cannot scratch chip or peel off
Roy R.
- Holly, Michigan, USA
Electrophretic lacquer is probably what I'd look at first.2
finishing.com
Brick, New Jersey
I think you could also look at the technical papers published by Dr. Wim van Ooij a professor at the University of Cincinnati. He is a world expert on corrosion. He is very knowledgable about a new chemical species called bis-silanes. The formula is not SiH4.
Dave Fairbourn
- Sandy, Utah
Depending on the part geometry, quantity and bending involved, a PVD oxide film may be a good choice. Reference Letter 9693 for some choices of oxides.
Joe Kubinski
- Woonsocket, RI, USA
Dear Reader, please --
