Letter 32046
Blast media for stainless bars that leave
no iron deposits
WE CURRENTLY USE A SOFT STEEL SHOT TO BLAST SS. BARS. THE PROBLEM
WITH THIS IS THE STEEL SHOT IS LEAVING AN IRON DEPOSIT ON OUR
STAINLESS BARS, CAUSING THEM TO FAIL CORROSION TESTS. THIS IS A HIGH
PRIORITY ISSUE WITH OUR COMPANY, AND FINDING A NEW MEDIA THAT WILL
WORK IN OUR BLAST MACHINES FOR THIS PURPOSE.
THANK YOU!
Steve Roberts
TITANIUM- WIRE DRAWING - Wooster, Ohio, USA
I think that someone makes stainless steel shot. Glass breaks down
fast so is probably not cost effective.
Aluminum Oxide
YOU CAN USE WALNUT SHELL GRIT OR GLASS BEAD FOR THE PURPOSE OF
BLAST CLEANING YOUR PRODUCT.
RAJESH PATEL
- JAMNAGAR, GUJARAT, INDIA
You should also be aware of the pass through semi-automated
systems similar to wire drawing; however, you use power brushes.
The glass small spheres at 0.2-0.5 mmdia or larger if you find it.
Here in Romania will produce it.
Damian Dinu
- Constanta, ROMANIA
You may want to consider using Stainless Steel cut Wire Shot. The
hardness generally ranges between 52-58 Rc. The use of this media
will eliminate Ferrous contamination from you cleaning process.
Michael Deakin
- Buffalo, New York
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
