Letter 32030 Formulation of chromating solution++++ How to make chromic acid solution for post-galvanization treatment? What chemicals should be used and in what concentration? Pot. di chromate or Chromium hexa oxide or else, which chemical. Thanking you. Regards M Tonpe
++++ Your best source of formulation information is expired patents, M. But this is not pancake batter that you mix up on a kitchen counter from a dollop of this and a pinch of that; the manufacturing process is hazardous from beginning to end and you need to retain an experienced consultant to assist in the plant and process design, not get a formulation from the internet. Good luck!
Dear Reader, please --
Save
