Letter 32017
Does black oxide require baking?
I HAVE BEEN KICKING THIS AROUND FOR QUITE A LONG TIME NOW AND CAN
NOT SEEM TO GET A VERY CLEAR ANSWER TO MY QUESTION. WHEN BLACK OXIDE
COATING HIGHER ALLOY STRENGTH FASTENERS THAT ARE PLAIN AND ALSO ZINC
PLATED IS A BAKE REQUIRED TO RELIEVE HYDROGEN?
IHOR RAJCA
SHELDON ENTERPRISES LL/FASTENER DISTRIBUTOR - MIDDLEBURG HTS, OHIO,
USA
If the black oxide is formed by the hot alkaline process there is
no hydrogen entrapment. Hydrogen is formed in an electrolytic
deposition system at the cathode in acid solutions eg Nickel etc so
you have no worries with the black oxide.
Allan Bennett
- Hobart, Tasmania, Australia
Hydrogen embrittlement perhaps not, but most steel must see some
sort of pretreatment prior to black oxide. If the pretreat includes
cathodic cleaning or acid pickling, hydrogen embrittlement might be a
concern.
A couple of other interesting thoughts on this are (1) the new
Mil-DTL-13924 [link is to spec at TechStreet] for mil
spec black oxide requires post coating baking presumably for hydrogen
embrittlement relief. Black oxide has such poor corrosion resistance
by itself, we often end up with rusted parts right out of the oven!
Oiling the parts prior to baking is a stinky, smoky mess that I
wouldn't suggest. (2) Helicopter manufacturer Sikorsky no longer uses
black oxide due to what they claim was CAUSTIC EMBRITTLEMENT of high
strength steel. I'm not positive that the two had anything to do with
the other but it's interesting that the new mil spec and Sikorsky's
"no black oxide" edict coincided within months of one another! I
think there's a conspiracy here and it begs the question: is CAUSTIC
EMBRITTLEMENT removed by baking like HYDROGEN? Any insight into
either the mil spec rationale for baking or the phenomenon of caustic
embrittlement would be appreciated.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
