Letter 32010
Chef has questions about anodized
cookware
How is cookware anodized and does the process really make
it scratch and heat proof. Also, does the process not affect
the food that is later cooked in the cookware.
Manuel Oleaga
chef - Miami, Florida, USA
This is a very general response....anodized cookware is
made out of aluminum. To anodize aluminum you dip it in
dilute sulfuric acid and run voltage through it, then you
seal it with chemicals and/or heat. What this does is grow a
thin ceramic layer (aluminum oxide) that helps protect the
raw aluminum. It will "help" protect against scratches, I
doubt it has a noticeable affect on heat loss.
The process shouldn't hurt the food later on, it may help
protect it. I've heard horror stories about medical symptoms
caused by cooking with aluminum pans...but after researcing
it for a bit I found no solid evidence that it will affect
ones health. The worst foods to cook in aluminum are starchy
foods that will absorb trace amounts of Al. and then you
ingest it. The anodized ceramic layer will keep food from
absorbing the Al. and causing possible problems/flavoring
the food. Last I knew Al. cookware was not monitored by the
FDA. It could be a a health risk or just a rumour, I don't
know and there are many opinions leaning either way.
Jason Aube
- Flint, MI, USA
March 25, 2006
To add to what Jason said, the aluminum oxide finish that
is produced by anodizing is the same aluminum oxide that is
used as the abrasive in sand paper. It is hard indeed! The
dark cookware like Calaphon has a very heavy layer of
anodizing which is therefore more wear resistant than the
thin clear anodizing you would see on pots and pans that are
aluminum colored.
finishing.com
Brick, New Jersey
