Chemical Conversion Coatings on Al
What are the differences/similarities between Alodine, Iridite, and Mil-C-5541 Chemical Conversion Coating.
DARIN G [last name deleted for privacy by Editor]
- PORT WASHINGTON, New York
Alodine (Henkel) and Iridite (Macdermid) are trade names of two of the approved materials for MIL-C-5541 Chemical Conversion Coating of Aluminum, Darin.
If you are asking if there is a difference in the appearance of the different coatings, the answer is yes. I have used several types of conversion coatings and they each seem to have a slightly different hue. Although most applications are for a paint base we do have customers that use it as a final finish and have certain color requirements. I believe most do meet Mil-C-5541 but check with the manufacturer to be sure.
jim conner
Jim Conner
Anoplex Software
Mabank, Texas USA
Anoplex logo
per Mil-C-5541 acceptable finish can range in color from light yellow to dark brown, though too brown can result in powdery finish.
Pete Silver
- Portland or
