Selective conductive areas in anodized extrusion
I need some localised areas they remain conductive in an aluminum extrusion after anodizing. Can I press-fit a "washer" into the extrusion that is plated with a material that is inert to the anodizing process in order to leave a conductive contact area within the anodized part?
Mike Stickelman
Product Design - Dayton, Ohio
Yes, that's one way. Tapes, waxes, dipping compounds, caps and plugs are all possibilities. However, you may have a corrosion issue in that area, and unprotected aluminum will oxidize anyway, rendering it non-conductive. So the real answer is that you probably need to either chromate conversion coat or electroless nickel plate that area.
