Letter 30093
Stripping sulfuric anodizing off aluminum
I want to know whether its possible to strip sulfuric anodizing off aluminum and don't change the dimension of the parts. If so how can it be done?
Kenneth Mullins
anodizing plating shop - Woodside, NY, USA
No, it's not possible. The anodizing is not a finish that is added on top of aluminum like paint or electroplating. Rather, it is a conversion process whereby aluminum from the item combined with oxygen to form aluminum oxide. If you strip that aluminum oxide, even with zero attack on bare aluminum, the part will be smaller than when you started because some of the aluminum was consumed in generating the aluminum oxide.
For rough purposes, half of the anodizing thickness is consumed aluminum. So if you have a plate that is 1" thick and you want to anodize it on one side to .002" anodizing thickness, it will be 1.001" thick after you anodize it and .999" thick if you strip the anodize with no material loss.
finishing.com
Brick, New Jersey
Dear Reader, please --
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
