Letter 30064
Oxide layer removal needed for adherent deposition?
Is it necessary to remove oxide layer on mild steel prior to nickel electroplating ,in any case what would be the end result? What should I do so that elfy test and bend test will be met successfully (means for strong, adherent and homogenous deposit from Watts bath). I did an experiment of depositing nickel 20 micrometer thick and heat treated it in inert atmosphere but the coating was not adherent in the end.
Mazhar ul Islam
researcher - Islamabad, Pakistan
In brief, the steel must be cleaned to a waterbreak-free condition, rinsed, then acid-dipped and rinsed. Yes, the oxide layer must be removed for adherent plating.
finishing.com Inc. - Brick, NJ
Dear Reader, please --
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
