Letter 30024
Non-conductive metal for lightning rod
I'm asked to bid a 130' tall pole with a 2'6" base and ground mounted in Las Vegas Nevada is there any non conductive metals I could use.
Kevin Watson
set builder - Van Nuys, California, USA
First of two simultaneous responses ++++
NO. By definition, metals are conductive. Maybe fiberglass? In any case, for something that tall you need a structural engineer.
Tom Gallant
- Long Beach, CA, USA
Second of two simultaneous responses ++++
Metals, by definition, as electrically conducting. The only way to make them "non conducting" is to put an insulator, such as a piece of plastic, in series between two rods.
R&D practical scientist - UK
Yes you can use a Aluminium with Zinc plating bar which is fully non-conductive. It is used for engine testing on turbofan systems. Its an expensive but safe option.
Jhon Smith
- Las Vagas, Nevada
Huh?
We appreciate the response, Jhon, but I think you've certainly misunderstood something.
finishing.com Inc. - Brick, NJ
February 9, 2006
Where can I get some of that Aluminium with Zinc plating from? I have really bright bulbs for my car, and it is melting away the plastic plug. I want to make something that will stand the heat - this Aluminium with Zinc plating sounds like a good idea if it isn't conductive.
Alex
- Brisbane, Queensland, Australia
October 1, 2007
Teflon coating is a material which is zero conductivity and its melting temperature is 327 degrees celcius. Hope it helps
Rhodam Evans
- Johannesburg, South Africa
Dear Reader, please --
