Letter 30014
Sawtooth trimmed edge from pickle line
I have been trying to get rid of sawtooth on the trimmed edge off
the pickle line but this has led to a belled edge on the OD of large
coils. I am looking for any advice on what to try next.
Jim C
Pickle line manager - East Chicago, IN, USA
Edgetrimmimg on pickle lines can be very tricky. We have seen this
sawtooth many times and it can also occur on slitters also. First you
must get your operator to understand the slitting process. Then your
knife and rubber combination must be correct on your edgetrimmer to
get the proper cut and break. You do not want to run your uncoiler
tension very high at all. This will cause the strip to pull tight and
the knife to slip, which in turn cause the sawtooth. Try running your
uncoiler break low and allow the slitter torque to run high enough to
allow for a 3 to 4 foot loop after the edgetrimmer. The key is
finding the right tension at the right speed.
Mike Sauls
- Ghent, KY, USA
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
