Need Teflon re-coating services for pots & pans
Disambiguation --
• If you're looking for repair spray; it seems no longer available, but please read & comment on Thread 10027 or Thread 12601
• For info on how non-stick coatings are made & applied, please see Thread 14968
• This thread is for those seeking a service to re-apply non-stick coatings to their cookware
November 27, 2021
Q. Hey there,
I'm Sonia and I have zero knowledge about cookware coating, so I'm coming here for help since I couldn't find an answer to my question anywhere around the internet, and I tried quite hard.
So,
I have a cookware part (a pot for a Jetboil portable stove) made from anodized aluminum which got a bit of a burn from food at the bottom.
I'm trying to find a way how to fix it, but I haven't found any local company that does re-anodizing.
Although I'm planning to send another pot for Teflon recoating, and I was wondering, if it would be a good idea to recoat the anodized pot with Teflon and if there would be any side effects? Or if it could potentially damage the pot even more?
Thanks in advance for any help.
Sonia
- Brno, Czech Republic
A. Hi Sonia. You may not find your local company willing to do teflon coating on that Jetboil pot either :-(
As I understand it, Jetboil pots are not simple pots, but are built with special heat gathering aluminum ribbons, and I would be reluctant to re-engineer the heat transfer on such a product by applying teflon in place of anodizing.
November 2021
November 29, 2021
Q. Hi Ted,
Thanks a lot for your answer.
Can you please explain what exactly "heat gathering aluminum ribbons" are?
Is it the bottom part underneath the actual pot? If so, I think it may be removable (I'm not sure if it is because I don't have it with me at the moment), so if you're left with really only the actual container, is it still a bad idea? Would it make noticeable difference in physical properties to put on a different coating?
I just want to make sure if this is really not an option. :)
Thank you again.
A. Hi Sonia. If you google "Jetboil" you'll see the video explaining their "Flux Ring" designed to make their pots heat up very fast. You've already burnt food in it and destroyed the anodized coating ... maybe it works :-)
You're free to do anything you wish if your applicator can do it for you. But we all have our personal concerns ... and while teflon on normal pots & pans doesn't bother me, adding it to someone else's special design does. It might dangerously overheat; and if it doesn't, it still might interfere with the heat transfer enough to spoil the idea of Jetboil. I'm only saying I personally wouldn't do it, not that you can't.
November 2021
Hi Ted,
I see, that makes sense. I probably won't do it then.
Thank you again for your answers.
Have a great day.
Cheers,
November 29, 2021
Q. Do you know how I can have a large glass skillet, longer made by Corning, refinished with a stick free surface. It is only 3 years old and they no longer make them. Please help! Justin
Justin Thyme- Winter Springs, Florida
A. Look up "Frypanman.com" -- they offer that service. Good luck.
Ed. note: Long ago there was a time when there was a Frypanman.com which offered this service, but it seems that they went out of business many years ago. Since then that domain name has pointed to link farms in Costa Rica, Japanese electronics sites, and probably other stuff :-)
Q. I am writing from the Republic of South Africa I have been trying to find a company to re-coat kitchen utensils which the Teflon coating has worn off of. I have been unsuccessful. Is there someone who can help either by informing on how the process is done or going further and maybe starting a business venture. I have found that there is a great demand for this and no known solution to this problem in this country.
Hoping to hear from SOMEONE.
Rath Wilson- Pretoria, Gauteng, R. South Africa
A. There is a company in Durban that might just be what you are looking for.
Dave Brackenridgeaerospace plating - Germiston, South Africa
Teflon Coating Service for Waffle Irons
Q. I am a professional chef and I have recently purchased a used cast material electric waffle iron that has been acid dipped and has some problems with sticking. I found this forum and thought I would chance asking if it is possible to have this item coated with teflon. I don't really know where to begin my search. The average prolonged temperature of the machine is 325-450 °F for about 3 hours at a time on a daily basis. Is there a product that I can purchase to coat it myself or do I have to take it to a machine shop that uses teflon?
Randy P [last name deleted for privacy by Editor]- Charlotte, North Carolina
A. There's a company in Oregon that re-coats fry pans called Continental Companies.
Jack S [last name deleted for privacy by Editor]- Penticton, BC, Canada
Q. I own some high quality aluminum pot and pans that are about 20 years old. The Teflon coating is starting to go away. Is there some place in the San Diego area that will re-coat these pans?
Randy Hammercustomer - Escondido, California, U.S.A.
Gentle readers: Google and other search engines are for "live" searches whereas Finishing.com is intended to be a permanent technical reference covering every aspect of metal finishing. In the old days we posted sources, but the world and the internet changes so rapidly today that 90% of links, brand names, company names, distributors, and sources posted here go bad in short order anyway. So, to the extent possible, please try to help us keep this site technical & maintainable, and to render unto Google that which is Google's.
Non-stick coatings for stove drip pans
Q. I am a housewife with an idea. I am trying to determine if there is a practical way to put a non stick coating similar to what is used on frying pans or the new celebrity grills onto the drip pans for electric stoves. If the coatings on the new grills and rotisseries on the market can withstand the heat then it should be possible to make a drip pan from the same substance. Not everyone has the new ceramic top stoves and I believe there are other homemakers who would welcome the idea. I think the result could be marketable and I would love to see a company try to produce something like it. Replacement drip pans currently come in chrome or black enamel for about $5.00 each but food and spills don't always scrub off after they have been cooked on. The new grills simply wipe clean when they cool off no matter how nasty things cooked on. Thanks for listening.
Joyce Brauerhobbyist - Centerville, South Dakota, USA
A. You may be interested in looking at a company called The Fry Pan Man. Search internet under teflon re-coating.
- Tualatin, Oregon, USA
A. Anything is possible, it depends on the profits and the demands.
Daryl Yeung- Hong Kong
Non-stick Drip Pans
on
A. Nonstick drip pans in various styles for gas and electric stoves are available in Brylane's kitchen catalog.
Peter LaHue- Freeport, Michigan
A. I could not find them in Brylanes Kitchens, but I did find them at The Home Marketplace. I have been looking for them for a long time. I just ordered, so I don't know if they are good or not. You will have to order like me to see I suppose.
Good Luck.
Geraldine Sessa- Radford, Virginia
!! Better not have any pet birds if you want to introduce non-stick on your drip pans! Heated, these can kill your birds in minutes. Read the following links before you use ANY non-stick stuff in a household that has pet birds:
http://www.ewg.org/reports/toxicteflon/es.php
http://www.ewg.org/reports/toxicteflon/toxictemps.php
http://www.ewg.org/reports/toxicteflon/slowdeath.php
- Pickering, Ontario, Canada
Gentle readers: Sorry, all of these links went bad. Finishing.com is intended to be a permanent reference, but links usually last no time at all. Please try to post the Title of such articles, and the Author if possible, rather than a link, so our readers have a fighting chance of finding them in this rapidly changing world :-)
A. There is a Teflon coating manufacturer in Surrey, BC, Canada. They do industrial coatings for waffle plates but they will also accept small jobs on occasion, while they are not too busy. They are called Slick Coatings and Solutions try them out they might be able to help you out. Good luck.
Marianne
- White Rock, BC, Canada
October 22, 2008
A. There is a company in Langley BC that does teflon coatings. The company name is Cantech Precision Coatings Inc. They specialize in coating equipment for the food manufacturing industry.
Garth Jackson- British Columbia Canada
January 20, 2009
A. There is an industrial coating business in Fairburn, GA who does Teflon based coatings. Newco Industrial Services (Newco Enterprises, Inc.). Ask for me.
S Hill- Atlanta, Georgia USA
September 29, 2011
September 30, 2011
If anyone wants to offer the NAME & TOWN of coating services that do waffle irons & cookware, that's okay! But please omit any 'testimonial' aspect. (why?) The internet is largely anonymous and some "recommendations" were submitted by company representatives posing as satisfied customers; we've had to discard some postings and do significant editing out of sales pap on others. Thanks.
RFQ: This is probably a question that has been answered many times before but I need to find a company that will recoat some teflon fry pans. One of them is electric. Can anyone help me?
Roberta Meisel- Fenton, Michigan
A. Roberta,
This site mainly deals with mainstream industrial platings and coatings. Teflon coating of pans is a specialized niche, and not a common industrial process. Your best bet may be to call the manufacturer of the pan.
Tim Neveau
Rochester Hills, Michigan
A. Hi Roberta. There have been a few companies doing this at one time:
- OPI, 2208 S. 19th St., Sheboygan, WI was mentioned in the Minneapolis Star Tribune in the FixitUp Answer and Question section many years ago, but I don't think they offer that service anymore if they ever actually did. It's not mentioned on their website (opicoatings.com) and it could have just been a misunderstanding by an overeager reporter :-)
- Frypanman.com in Vancouver, WA was another service, but that domain now seems to be just a "link farm" for many years now.
Some shops that do teflon coating have told us that it's possible to re-coat pots & pans, but except for exotic chef's pans not really economically feasible -- the old issue that the labor time of onezy-twozy refinishing makes it more expensive than a mass-produced replacement.
No! No! No! Q. Many years ago I purchased a spray can of Teflon coating from a hardware store. I sandblasted my waffle iron and followed the directions on the can. It was then baked in my oven and has served me for many years and looks as good as the original one. I haven't been able to find this product again WHY? John Grafton- Clermont, Florida 2002 A. Hi John. To quibble over details, I doubt that the spray was exactly teflon. Please see thread 10027, "NON-STICK COOKWARE SPRAY TO FIX POTS & PANS?" which has hundreds of entries on that subject and concludes that it is no longer available anywhere, and guesses why, and explains exactly what that spray actually was :-) Although there are teflon sprays (lubricants) available in hardware stores, and bake-able non-stick coatings available from gunsmiths, they are NOT food-safe! They may contain petroleum distillates and other poisons -- don't even consider it. Luck and Regards, Ted Mooney, P.E. Striving to live Aloha finishing.com - Pine Beach, New Jersey |
Seeking Teflon re-coating service
Q. Seeking Teflon re-coating spray or service in Cape Town, South Africa to re-coat frying pans, etc. It seems to me that this niche (re-coating food utensils) is not being exploited, so there might be scope for someone with a solution to this problem.
Ivan Copelowitzconsumer enquiry - Cape Town, Western Province, South Africa
Q. Do you think the guys that resurface pots and pans can resurface some metal electric heaters, the kind that go inside solution?
Rodrigo SalinasMetal Finishing - El Paso, Texas / Cd. Juarez, Mex
A. I have used the Frypanman services for my restaurant with very successful results. They don't last quite as long as the original teflon coating but it lasts long enough, saves a lot of money and keeps my pans out of the landfill.
Paul Kuck- Eugene, Oregon
Ed. note: Update Dec. 2013 & Nov. 2021 -- The domain frypanman.com has been just a link farm for many years; if anyone has knowledge of what happened to that service, please update us.
Recoating Teflon for Jenn Aire grills
Is there a way to recoat the teflon that is coming off of my grills on my Jenne Aire outside electric grill. new ones from Jenne aire are $69 each and I would need four of them. Is there a less expensive solution?
Pat McDonaldhome owner - Leesburg, Florida
A. I'm sure your grills could be sandblasted, and re-teflon coated. I also would imagine it would be cheaper than $280. Look in the Yellow Pages under either painters, and/or Powder coatings (a lot of places do both), and you should be able to find a job shop that can handle the job. Make sure they use "food grade" teflon.
Marc Green
anodizer - Boise, Idaho
Recoating a Griddle
Q. I have an expensive stove griddle that is made of cast aluminum. It seems to have a dark, maybe "teflon" coating over it. The coating is waring off. To find another griddle is difficult, or impossible. I need to restore this griddle.
What are my options? I understand to recoat this if it is "teflon" is maybe not possible anymore. Since it is aluminum cast metal, can another process recoat it? How about "powder coating?" If there is any other process available out there, please direct me to the sources. Thank You.
- San Clemente, California, USA
February 6, 2010
Q. Is there a business that will resurface an electric fry pan. It has handles that can be removed (plastic) otherwise all metal. This pan is obsolete and I have 2 of them because they are perfect for 2 people. Can the product on the new fry pan advertised on tv be applied to an old fry pan? Would like to contact someone that does reapply non stick coating.
martha stokes- waterloo, South Carolina
March 25, 2016
Teflon Finish on catering pans
Q. With regard to the refinishing of Teflon coating on catering equipment and having read quite a few threads on the subject ...
To me the answer that we may be looking for is not Teflon coating (which is a mineral based product which is not cleared for use in catering refinishing products) it could be the old fashioned system of "Stove Enameling" whereby the used catering equipment is blasted with bead or other means then the base metal is polished up then the paints are applied in a series of layers, then the unit is baked in an oven to produce the stove enameling effect.
Am I on the right track or tell me if I am wrong.
Awaiting your replies
Martin.
hobbyist - DUNS, Scotland, United Kingdom.
September 30, 2018
Q. I have two pieces of Club with old scratched Teflon that is no longer useable. Before I throw them out, I would like to know if there is someone out there that would remove the remaining Teflon and finish the surface back to a useable one. They are both in great shape except for their surfaces. Thanking you in advance.
Jimmie Smith- Amarillo, Texas USA
February 29, 2016
A. Hi Jimmie. It's an expensive process so the applicators seem to focus on industrial and restaurant cookware more than residential.
But google "repair nonstick cookware" and you will see at least a couple of companies offering to do it for premium residential cookware.
February 2016
A. We re-coat griddles and other cookware. www.thermech.com
Eric Shah- Anaheim, California
November 3, 2020
