Plating on plastic
Seeking info on supporting electrolyte use in nickel plating on different types of plastic. please don't hesitate to give me a help. Thanks.
I want to make Polyester or Plastic covered with nickel and I don't know which process. Does someone know a process that can help me?
Thanks a lot.
Youssef Ahbachou
- casablanca
We have a low temperature PVD process that works on plastics. The coating adhesion is great, and a wide variety of coatings can be deposited -- including hard coatings such as TiN and ZrN. We might be able to help you if you tell us your application.
jim treglio portrait
PVD Consultant & Wine Lover - San Diego,
California
Yes, but does that wide variety of coatings include nickel, Jim?
Metals are the easiest to deposit. Nickel is somewhat more difficult because it is ferromagnetic -- we use magnets in our arc sources -- but this problem can be overcome.
California
youssef, you may want to use a plating on plastic commercial process which is made on injection molded abs plastic parts. if your application is casted polyester resin (in rubber molds)then a different process should be used involving metallising the part,heavy copper plating it and then nickel plate. daniel
daniel livshitz
- tel aviv israel
