Stripping Tungsten Carbide thermal spray coatings from 300M steel
Q. We have a need to strip a tungsten carbide HVOF thermal spray coating (Diamalloy 2005) from a 300M alloy steel components. Somebody said citric acid [on
Amazon (adv.)] will do this. Any advice from out there?
Thanks in advance for your help.
Aerospace sheet metal, welding & thermal spray - Blainville, QC, Canada
A. Since you are Aerospace, you must follow the overhaul/repair manual of the OEM or get an approval for an alternate method (which can be lengthy and tough to come by). If you do not use the approved methods, and a part fails, just the law suit (lawyer cost) would break many companies. The downside of this type of individual effort is massive.
James Watts- Navarre, Florida
Don't assume, James Watts, that the person asking an honest question is less knowledgeable than yourself. Dick knows a thing or two about "aerospace". , EIT- Winnipeg, Manitoba, Canada 2005 James surely meant no disrespect, Jason. But for him to assume that a stranger knows what he knows is dangerous! Over the years he has warned a half-dozen people here who wanted to install chrome plating tanks in their garage/basement about the safety issues they were totally unaware of -- should he have assumed they are "not less knowledgeable than himself", and just give them the raw mechanics of how to install plating tanks in their basement? Ted Mooney, P.E. Striving to live Aloha finishing.com - Pine Beach, New Jersey 2005 |
A. Nitric acid may not do the job as the Nital Etch process used nitric acid and nital etching is used on HVOF layers to verify NO burning as result of grinding.
What we have done to remove the HVOF is just grind it off with the same grinding stones as used to grind the HVOF layer initially to it's roughness requirements. due to the hardness of HVOF coatings, these are special grinding stones.
I hope this is of help.
- EINDHOVEN, NETHERLANDS
Q. Nital etch inspection on PH 13-8 Mo and 17-4 PH steel. Is the Nital etch inspection on precipitation hardening steels effective? is there any influence from burning marks (grinding) on the outside diameter like on carbon steel heat treated products?
Peter AartsAerospace - Geldrop, Holland
Q. I need to remove chromium carbide coating from steel sample using any chemical methods without causing changes to the substrate. Thickness of coating is 20µ. Does anyone have information about it? Thanks.
Elena Sparrow- Moscow, Russia
January 14, 2013
A. Ultrasonically pulsed waterjet technology will remove hardcoating such as Chrome and HVOF using normal tap water without causing damage to the substrate.
Jeff ShafferPratt & Whitney PurePulse Technology - San Antonio, Texas, USA
January 31, 2013
Q. Dear Sir,
The problem is stripping of chrome carbide embedded on steel substrate. It is not going with HF and caustic-peroxide mixture. Can you suggest to me some other strippers?
- Bangalore, Karnataka, India
March 31, 2013
Stripping Tungsten Carbide from I.D housing
Q. Stripping Tungsten Carbide from I.D housing what methods can be used.
Any suggestions would be greatly appreciated.
- Edmonton, Alberta, Canada
October 26, 2017
? Hi Sashi. Your housing is made of 300M steel, or something else? What is the length and diameter of this I.D.? Is it open on both ends, or a blind hole? It's not yet clear to me what is inapplicable about the earlier suggestions ... can you comment on them please? Thanks.
October 2017
