Not getting nickel coverage on ABS
Hello everybody -- how interesting about electroplating.... I want to ask about the best conditions to plating ABS because I have a problem that some parts of the plating material are not covered with nickel.
Ashraf Abass hassen
chemiste - Alex, Montaza, Egypt
Mr Ashraf,
There can be 20 reasons for your grief. Please state your operational details so we know what you do. Then it will be possible to suggest a remedy.
asif_nurie
Asif Nurie [deceased]
- New Delhi, India
You did not give a description of your plating cycle to enable to see what is wrong with your process. Anyhow, lack of plating is normally related to not enough etching or not enough activation between the palladium and the electroless nickel.
sara michaeli
sara michaeli signature
Sara Michaeli
Tel-Aviv-Yafo, Israel
Dear Ashraf,
Covering of EN is a factor of
1-activation
2- acceleration
3-electroless
Plating condition etching is a factor of adhesion. Weak etching will result bad adhesion but it should be covered. So please check those 3 steps.
Best regards,
Raafat Albendary
- Cairo, Egypt
