Etching electroless nickel
In reference to tantalum etching, I use a mix of HF, nitric, and water to etch electroless nickel. I want to get as rough a surface as possible without degrading the photoresist. HF in concentrations >15% seems to creep under the resist (more than nitric variations). Does anyone have a recommended alternative?
Kevin Keating
plating - Rochester, New York
Gentle man,
ferric chloride [on eBay or Amazon (adv.)] in combination with HCl and Sodium chloride shall give you the desired finish on EN. Timing shall vary from few seconds to few minutes depending on your requirement.
Shankara Narayanan N
- Bangalore, Karnataka, India
