Plating for High Strength Steels
What is an appropriate plating material and process for high strength steels (Ftu = 240,000 psi) to avoid hydrogen embrittlement? Plating is for corrosion resistance and bearing surface.
Dale Roberts
aircraft structures engineer - Medford, OR, USA
You may want to investigate mechanical plating.
Guillermo Marrufo
Monterrey, NL, Mexico
