Antique Finish on Brass Zip Fasteners
"Zipper: An Exploration in Novelty"
by Robert D. Friedel
zipper
or eBay or
Q. Would like to get hold of a process other than electroplating to achieve antique finish on Brass Surfaces. The Brass surface is that of a zip fastener used in garments. The Antique finish should not wash away and should not stain garments when garments are washed.
Existing non-electrolytic process produces inconsistent results including stripping of the antique layering during washing with standard household detergents.
B.S.Sastri
Technical Director - Chennai (Madras), Tamilnadu, India
A. Hello, cousin. They can be 'blackened' then have a tough clearcoat applied. What is your "existing non-electrolytic process"? We wouldn't want people to suggest a process, only for you to then say that's the one that isn't working :-)
Q. Ted, I've run into this same problem often with our zipper suppliers. They all seem to be using the same manual process to antique brass zippers - The zippers are washed and degreased with hot water and detergent, rinsed, then dipped in a light blue room temperature solution to darken the teeth. I'm no chemist, but the blue solution looks just like the selenious acid antiquing solution often used by hobbyists. It creates a good appearance, but is not at all durable and can create stains in light colored garments. A clear lacquer coating sometimes improves finish durability, but as I'm sure you understand it's hard to glue down a finish that was never properly adhered to the base to begin with. Any ideas for a better process would be appreciated. Thanks!
C.J. Gardener
- Charlotte, North Carolina, USA
November 1, 2011
