Steelcase Tanker Desk Restoration Tips
< Prev. page (You're on the last page of the thread)
"Steelcase the
First 75 Years"
by Steelcase staff
on
AbeBooks
Q. I asked this question sometime ago, but got no response.
So here goes again. I have a gray steel table with a soft clay like top. I recall this type of desktop 50 years ago.
When it got dinged up you poured this mystery liquid on top and it would melt the clay and as it dried, the top would be restored to a nice finish. Does anyone know what this liquid was or the contents there of? Please help, the war department is wanting to throw this fine table out on the street.
- Birmingham, Alabama
May 5, 2009
Please try to 'engage'
This worldwide meeting place welcomes Q&As, photos, history, & interesting tidbits -- but it's not a consultancy.
Like a great cocktail party ...
• but if people don't engage about the situations others are in, just introducing their own items & issues, it can produce long strings of unanswered questions, which doesn't attract potential helpers
Q. I also need to know how to clean up a linoleum-type desk top.
It's a dark gray... not in bad shape, but could use a good cleaning to get pen marks, scuffs, etc. evened out.
- Lakewood Ohio
May 9, 2009
Q. I am looking into restoring a vintage tanker desk. I found one in really good shape but it has the formica top and I would like the all steel look. I am wondering if anyone knows if it is just steel underneath the formica if I removed it or is there a different material under there? Thanks, any help would be appreciated.
Angie BanderHobbyist - Rice, Minnesota
July 21, 2009
Tanker Desks and Parts on eBay
I am wondering if anyone has any experience of restoring a 1950's HON Steel (Tanker) Desk.
We are going to have the unit sand blasted to get rid of the rust and the lovely (ahem) gray paint to get the shiny metaled look.
After this is done were unsure what needs to be done after that.
Does the metal need sealing, in some way shape or form?
What are our options on the top of the desk, currently some form of trashed rubber? Where can we find replacement/alternatives?
There is an Art Deco looking rubber surround enclosed in an Aluminum rim (pardon the terminology). We would like this completing in Aluminum. Suggestions very welcome.
Any advice would be really helpful.
Thanks in advance,
Chris
fashion design - Columbus, Ohio
July 19, 2009
Table Protectors
hard or soft
24" x 48" & other sizes
A. For all of you with torn up desk tops:
Just have a piece of glass cut to fit over the top. It costs about $150.00 for 1/4 inch, radius corners with the edge sanded. I have an old tankers desk with ugly wood laminate. I got some beautiful wall paper with a large graphic print & slipped it under the glass. It looks wonderful & I can change the look of the whole room by changing the wall paper.
Q. I have heard that the rubber edge cannot be replaced once removed ... something about the way the manufacturer installed it -- can anyone confirm this?
What is the best way to remove spray painted numbers & permanent markers?
- Vancouver, Washington
October 2, 2009
Ed. note: Isopropyl Alcohol [on eBay or Amazon (adv.)] should easily wipe permanent markers off.
A. Hi:
I've restored a couple of these steel desks for my home and office, and here are some things I've learned:
1) Always try to retain as much of the original paint as you can. It was baked on and is much more durable than the paints most of us will be using. The original color can be closely matched if you take a piece of the desk to a professional paint store that uses a computer-matching system. They will hold an artificial eye machine against the desk piece, and then the computer will generate a recipe for the color the eye "sees." (Although the metallic content of the desk paint usually throws the computer color off a bit.) For one of my desks I only had to repaint the front of the desk drawers; I left the rest of the desk alone even though it wasn't "perfect." Although only the top drawers were dirty and scuffed, because the mixed color was ever so slightly different from the original paint I repainted all the drawers so that it wasn't obvious that only two of the drawer fronts were repainted. Even when I've repainted the whole desk, I've kept as much of the original paint as possible and sanded it to use as a primer. One last thing about these professionally-mixed paints: they're expensive -- about $20 per spray can! But they're professional paints that are tough and have a short drying time, which making the job of painting go a lot faster.
2) These desks can be taken apart. This makes them easier to restore and paint. Missing pieces can be cannibalized from a damaged duplicate desk purchased very cheaply. To do this, however, you should know which pieces you're looking for and make sure that the duplicate desk has them. This means that you have to take your desk apart and then wait for a damaged duplicate to turn up -- which might take a while, during which you can't use the desk you're restoring.
3) If you love the brushed-steel look, paint the desk in a metallic silver or metallic gray. Taking the paint completely off and clear-coating the desk is not wise -- you're simply asking for rust. The desk won't look nice for long, and you'll just have to restore it again.
4) Linoleum tops can be restored using a hot air blower
[on
Amazon (adv.)]. Similar to a hair dryer, these machines can be purchased for about $20 at a hardware store. They produce a small beam of extremely hot air. Directed towards the top of the linoleum and moved back and forth, you can heat areas of the linoleum until it gets soft and mushy. Then you can use a marble rolling pin [on
Amazon (adv.)]
to smooth out the surface. Deeper ruts in the linoleum can be gently shaped with a spoon and then rolled out. I've found that this technique works best using a two-person team: one person runs the blower and the other person rolls the rolling pin over the area being heated. (You have to watch out not to get burned, however!) Letting the linoleum heat until it slightly begins to bubble seems to work best for me. Although the former dents and gouges might still be visible (they often leave a discoloration or "ghost" of their former shape), you can get the linoleum back to a smooth writing surface with a little work and elbow grease. But it's worth it -- linoleum is a natural material and is soft and warm to the touch. Also, you'll be restoring the original desktop, and any time you can keep an original part to the desk, you should. The linoleum should finally be coated with a protective surface of floor wax specially formulated for linoleum.
Those are all the tips I can think of at the moment. Restoring these desks takes time but if you are careful and do a good job the results are well worth it. Do you think the particle board desks you purchase at Office Depot or Office Max are going to last 50 years or more? These steel desks have been around at least that long and with proper restoration and care they'll last another 50 years. Think of your restoration work as an investment.
Good luck and have fun!
-- Kenny
- Milligan College, Tennessee
November 3, 2009
Ed. note: As noted, linoleum is a natural product; it is not the same thing as modern vinyl. Modern coatings might be inappropriate, and old style ones are impossible to find. Some people say to add a few drops of baby oil [on eBay or Amazon (adv.)] when cleaning the linoleum with a mild solution of detergent and vinegar [in bulk on eBay or Amazon (adv.)]. What won't hurt a baby shouldn't hurt linoleum :-)
I have an old Steelcase desk, believed to be a Tanker desk with 3 drawers on the right and 2 on the left with a center drawer. My dad has had it forever and I only recently noticed the high quality design and it simplicity. It's in great condition but is missing the center drawer lock and one handle. Does anyone know of a good source for these items. Any suggestions would be greatly appreciated.
p.s., I do plan to refinish the desk and thank you all for your suggestions.
- Thousand Oaks, California
November 19, 2009
Q. I have an old Steelcase-esque (actually made by a now-defunct company in Philadelphia, PA) desk that I want to take apart to move since it is extremely heavy to move as-is. How do I do this? Does anyone have any tips on where to start? I've poked around a little bit but thought I might ask before I really start crawling around. I imagine the top comes off and then the two pedestals separate from the metal that holds them together, but I can't figure out where/how to start.
Thanks for any pointers!
- Washington, DC, USA
July 15, 2010
A. Hi, Kay
I doubt that you'll find anyone with assembly directions for such an old desk, but the usual best way to start is with the desk lying on the floor upside down for safety and practicality. You'll be able to see the fasteners without climbing under the desk, and you won't be risking something falling on your face when you loosen it :-)
Q. Did anyone ever get a response on the name of the auto body shop in Denver that will refinish the tanker desks? Need to find one asap - can't leave on truck much longer! Thanks for any help in locating a Denver shop - just picked up one yesterday - have started calling around. Mary Krohnfeldt- Denver, Colorado September 18, 2010 Ed. note: This site is for permanent reference, so it's good place for posting technical problems & solutions -- but apologies, it's the wrong place for sourcing info. Businesses move, change their phone numbers, close, websites get rearranged, new businesses open, etc. We don't want this site's 250,000 postings to devolve into a whack-a-mole mess of outdated historical sourcing info :-( |
Q. I recently purchased a great tanker desk is fairly good condition from the Habitat for Humanity ReStore -- the university in our town has started to provide the store with it's surplus furniture items! In the future, I'd love to have the desk powder coated -- but for now, it's clean and sturdy.
The rubber on the top is not peeling up -- but it is a bit worn, and I would like to clean it up as much as possible. When I cleaned it with a basic all purpose cleaner, a significant amount of gray/black residue came off of the desk. Each time I sprayed it down, the same amount of residue was on the paper towels.
I'm wondering if the rubber is breaking down - or if I'm simply not cleaning it properly. Perhaps there is a way I could seal it?
Any advice some of you other hobbyists could provide would be very helpful!
Hobbyist - Athens, Georgia, USA
November 16, 2010
I recently came across a couple of General Fireproofing desks and I want to remove the formica top and use glass. But in doing so, I need to replace the aluminium edge that edges the desk top. It's in pretty bad condition. Does anyone know of a website I could find material to replace the edging? Thanks, Brad
hobbyist - Decatur, Illinois
March 20, 2011
A. I have a desk like Mr. Taliaferro's pictured at the top of the post (no pedestals, just a pencil drawer). The laminate top was cracked so I took a screwdriver/chisel and hammer to it and scraped it off. The surface underneath is stained with old, red glue. Not bad, just ugly. I don't think it's worth the trouble to replace the laminate. The non laminated surface was smooth enough after some sanding. Luckily, the family business is auto paint/body.
I'm going to cover the top with chalkboard paint [on
Amazon (adv.)]
after primer [on
Amazon (adv.)]
for a nice smooth surface. The hardware store also sells dry-erase board paint too.
In my opinion, replacing the laminate if it's cracked is not worth the time finding the laminate and installing it. Painting it is way easier.
After taking the desk apart, I've begun to sand the paint off the rest of the desk to the metal with an orbital sander and 80 grit sandpaper. Then my husband will prime it and paint it. I've chosen a BMW interior color for the rest of the desk. My husband's family has a ton of experience with paint/body and they said that sanding and painting would be the best way to go about restoring this desk. Other options are too expensive and time consuming.
- Tucson, Arizona
July 6, 2011
A. I used gel paint remover [on
Amazon (adv.)]
, naval jelly rust remover [on
Amazon (adv.)]
, sandpaper, and car wax
[on
Amazon (adv.)]
. I did this to my tanker desk 2 years ago, live a block from the ocean, and don't see any rust.
I was going to clear coat it with this stuff they sold at Home Depot that says it prevents rust but was lazy and just waxed over the sanded steel. I did wipe it down with WD-40
[on
Amazon (adv.)]
before waxing. I'm not an expert but am happy with the results.
I left the drawers original paint and I get compliments all the time. I found a matching chair on Craigslist: desk $60, chair $75.
Mutt Lee
- New York, New York
March 4, 2012
Q. I have a 1950s Steelcase desk that I got at an architectural salvage store. It has 2 drawers on the left and a space for a return on the right. The return was not attached when I bought it (nor was it attached when it was salvaged). I have 2 metal bracket pieces, but I cannot figure out how they all go together to attach the return. Does anyone know how they attach or where I can find information about how to attach the return? Thank you!
Rachel Nugent- Kansas City, Missouri, USA
May 3, 2012
Q. My wife just purchased an Art Metal tanker and I am tasked with the disassembly for the eventual blasting and powder coating.
The laminate top isn't in bad shape, but it has to come off, and therein lies my question.
The desk looks to have some metal end caps that seem like they would pop or otherwise be able to be removed but I don't want to use excessive force. Haven't flipped it over, so maybe there are some anchoring screws there?
I think once those are removed I should be able to use the putty knife and pry off the laminate. I just don't want to damage the end caps.
Thanks in advance for any advice!
- Springdale, Arkansas, USA
October 1, 2012
Q. Hi I am going to refinish a tanker desk and I was wondering if anybody has any thoughts on scuff sanding and using lacquer spray paint on the metal and possibly the same paint on the Formica top. Thanks
Robert Beach- Santa Barbara, California, USA
January 20, 2013
I answered my own question! It worked great, scuff sand, 4 coats of white lacquer, wet sand each coat, 4 coats clear lacquer, wet sand each coat and buff with car polish.
Robert beach [returning]- Santa Barbara, California, USA
February 1, 2013
Ed. note: Sounds beautiful, send a pic :-)
Q. Can you tell me where the asbestos is normally found in these desks? I want to check mine to see if it contains the asbestos fabric/padding. What is the best way to go about removing the padding if it is present?
Megan Black- Atlanta, Georgia
July 9, 2013
Q. Hello. Can anyone please advise where I can purchase parts for my tanker desk? I'm specifically looking for the round plastic rollers inside the drawers. Any help would be greatly appreciated. Best regards, Mike.
Michael Biehl- Setauket, New York, USA
February 22, 2014
A. I suggest contacting Berkeley Outlet in Berkeley, California.
La Ronda Bucciarelli- Inverness, California USA
January 10, 2015
Q. I have a tanker desk and want to start using it but the drawers pull really hard almost like they stick. What type of lubricant would I use.
Thanks in Advance!!
- Wausau, Wisconsin
April 20, 2015
A. I would use a dry graphite [on eBay or Amazon (adv.)] to lube the drawers or a little candle wax.
Markam R campbellhobbyist - Pullman, Washington
May 15, 2022
A. I have had my tanker desk since 1990 where I use it in my home office. All the drawers open and close smoothly on nylon rollers which should not be lubricated. The center desk drawer with the pencil holder in it does need to be lubricated periodically. And for this I use a plain white lithium grease ⇨
This works well and doesn't attack the paint. Slide the drawer out and empty it if you wish. Then remove it completely. Looking at the tracks under the desk it will be obvious where the old grease was. I clean it out with a few cotton tipped swabs. Same for the drawer itself. The grease I buy comes in a squeezable metal tube. I just add new grease to the front half of the sliding surface attached to the desk, and the rear half of the sliding surface of the drawer. Slip it back in and it opens and closes a lot easier and smoother. The grease will migrate on its own to the entire areas that need it. One application lasts me well over a year.
- Schenectady, New York, USA
July 20, 2015
Q. I have had this steel desk (ALL of it top included is steel ... very heavy) since 1998 and cannot for the life of me find any information about it ... can someone help with this? The gentleman I bought it from had it since the 60s.
That is all I know the corners are brass inlaid? And paint, etc. all appear original including the pencil tray in the center drawer.
Thanks in advance for any help at all Cristine
- Cave Creek, Arizona
September 7, 2016
A. Hi Christine. I'm no tanker desk expert, but I've worked at office desks for 50 years or so :-)
From the heavy look of it, and your statement about its weight, and the fancy feet, I doubt that it's from the 60s -- but probably the 40s or early 50s; maybe even the 30s from the lack of aluminum handles that have been used on almost all office furniture for many decades. Steelcase is probably the most common brand name, so I'd try that for some similar pictures on eBay , etc.
It's a small desk, probably not an executives ... maybe a teacher's desk?
September 2016
A. Your desk strongly resembles a small library table I recently purchased. The brand name is Shaw Walker and I believe dating is more like 1940-50's. And I believe those corner caps and feet covers are aluminum and can be polished up very nicely.
Try Google search "Shaw Walker student desk or small desk"
The top of mine is in horrible condition and I'll be trying the "melting" method mentioned in this thread after I clean it up as much as possible. I thought I'd replace the top with "Forbo marmoleum", but after looking at samples, I think it's too stiff to wrap around the bullnose perimeter. And lots of glue would also be necessary.
Good Luck,
SBerg
- Waukee, Iowa USA
October 18, 2016
Thank you for taking the time ... had it in my office for almost 20 years and bought from the original owner.
Cristine Orzel [returning]- Cave Creek
December 18, 2016
Q. Okay guys, in Sep '16 I asked about refurbing, etc., my little single pedestal desk. Well, just getting the rehab / repainting done :) of my 1941 Shaw Walker desk with brass corners and brass feet as well as brass around the lock and YES original Bakelite Drawer pulls in great shape. Am considering painting them to match the body of the desk :)
... I even got a key but am afraid to try it out; could not find a DWA 148 lock remover though? Anyone know where to find the lock remover key for that pre-Yale lock?
Now comes the dilemma. I can't safely get the pencil drawer in :(
... afraid of scratching. Attached is photo of where I am at right now ....do you try angle up or angle down rather than straight in? there is a spring on left side and a rubber stop on right to get around and onto the tracks
HomeSmart - Cave Creek, Arizona
August 9, 2017
Q. Hello all! Hoping I can get some type of answer to this, since google and YouTube have failed me. I have a late 60's teal tanker desk with drawers on either side (unsure of brand) that is unlocked, but only half the drawers open. They all opened in the store when I bought it, we transported it, the counter weights kicked in, and now 2 drawers won't open. Anyone know what the trick is to this? It's the middle left drawer(of 3), and the top right drawer above the filing drawer.
Luckily these things can take a beating, I'm about to that point x-D
- Fredericksburg, Virginia, USA
May 28, 2017
A. Hi Candace. These mechanisms were designed so multiple drawers couldn't be open at once, causing the desk to tip over, crush a foot, and spill everything. Each manufacturer probably patented their mechanism, forcing other manufacturers to do it differently ... so there are probably several different possible arrangements. But in any case, pushing the rest of the drawers in was supposed to free the remaining drawer.
What I would do is completely remove the drawers you can remove, then look up/down or reach up/down and see what needs to be pushed, jiggled, or held to free the drawer. I'd be virtually sure that it's easy with a drawer removed and difficult without. Once you free the stuck drawers, you can remove them as well and you'll have good access to fix whatever got bent or came loose.
May 2017
RFQ: I have a circa 1960'a steel tanker desk that has been in my family since the mid-'60s. I'd like to have it refinished/repainted along with some minor repairs, i.e. sticky drawers. I'm NOT INTERESTED in DIY. Any suggestions on getting this done in the Chicago area?
Even as old as I know it is (did my homework on this desk), it's still WAY better quality than the multiple desks I've had in the past 10 years. I decided to keep the tanker and dump the newer but poorer quality desk I currently us. Thanks for any help.
- skokie, Illinois USA
February 12, 2018
Automotive Wet Spray vs. Powder Coat -- 1950's Tanker Desk
Q. I bought a great 1951 ArtMetal two-pedestal steel tanker desk. It's in great shape structurally, but needs refinishing. After soda blasting to remove all the old paint, I am trying to weigh the pros and cons of bringing it to a body shop for wet spraying (more readily available in my area) or having it powder coated. What say you?
Karen Fox
Hobbyist - Saco, Maine, USA
June 18, 2018
A. Hi Karen. Whichever is easier will be fine. Obviously a tanker desk isn't exposed to the corrosive conditions a car is, and any decent pretreatment and painting or powder coating method should be fine.
A. Regarding painting an old tanker desk, just sand it, use auto-body filler on any dings or blemishes, and prime and spray paint. I used hard glossy black enamel spray from Walmart, it looks great.
My biggest problem is the top. Mine had the rubber surface, so I removed that. I guess painting and an epoxy surface would suffice, like I've read here in previous comments, but I'm more interested in a sheet of thin material to glue on and fit under the metal edging.
Q. My biggest problem is the top. Mine had the rubber surface, so I removed that. I guess painting and an epoxy surface would suffice, like I've read here in previous comments, but I'm more interested in a sheet of thin material to glue on and fit under the metal edging. I just haven't come across anything thin enough, and would appreciate any suggestions
Dave TicerDrywall professional - Prescott Valley Arizona
A. Am refurbishing a General Fireproofing 'tanker' desk. Removed the old soft surface pretty easily once I got started. Used a wood chisel and a beveled-edge putty knife with a hammer sometimes.
I would recommend NOT removing the steel band with aluminum nosing that edges the top. You can see underneath at the corners that the aluminum has a horizontal fin which is sandwiched under the steel sheet that the surface was glued to. Probably a tight, clamping fit. I don't see how you could remove it without bending it and certainly don't see how you'd get it back like it was.
The aluminum is only less than 3/16" above the steel surface. I'm thinking of using VCT tiles or sheet vinyl flooring to cover. Hope this helps.
- Garner North Carolina
September 15, 2020
Q. Can the top (linoleum or whatever) be stripped and replaced? My desk has a chrome thing on each corner and the top is rolled down under. I don't think I'll tackle this myself but would love a complete restoration.
Adam
Cleaning and restoring old stuff - Houston, Texas
March 13, 2022
Q. I have a Globe-Wernicke model 3-m-55 and the center drawer is unlocked ... but no key in case I do have to lock it. How do I remove the lock? There is no way to get behind the lock; there is a curved piece in the way. I really don't want to break anything. Is there an exploded diagram i can get? I tried the manufacturer and never heard back.
Markam R campbell- pullman, Washington
May 15, 2022
