Specific gravity of anodize solution and how to measure it
Could you please tell me what the specific gravity of the sulfuric acid solution is in a type II anodizing tank?. That is one with a mixture of 165.3 grams of 66 degree baumé sulfuric acid per litre of water. Is a hydrometer an accurate way to measure specific gravity.
Kind regards,
Steve Power
Engineer Aircraft - Nelson, Nelson, New Zealand
A hydrometer is not a good way to test your anodizing or hardcoat solutions and most other other plating solutions as contaminates such as aluminum [change the specific gravity].
Chris Snyder
plater - Charlotte, North Carolina
