Need metal dyes in different colors
Q. Is it possible to dye nickel and steel metals various colors such as red, blue etc. I have an idea but I need to see if there is a way I can get different colored nickel and or steel wire without painting or coating.
William T [last name deleted for privacy due to age of posting]
hobbyist - Livermore, California, USA
Q. Did you ever find an answer to your question on how to color steel or nickel?
Kip K [last name deleted for privacy due to age of posting]
- Anaheim, California, USA
A. How about getting it as clean as you can and then trying a magic marker (indelible marker)? That may be as close to a permanent dye as you will achieve on nickel and steel.
If the general idea works, you can get "alcohol inks" [metal dye / alcohol ink on eBay or Amazon (adv.)] in all sorts of colors, sizes, and brush types.
(Aluminum can be dyed much more permanently because an anodized coating is sort of like a honeycomb that can be filled with dye and then sealed).
Q. Hi there,
I am looking for an effective way to dye untreated Tungsten beads e.g. brown, green etc...
It needs to be indelible, waterproof and rub resistant.
I've done some experimentation with Industrial metal marking inks, but with no success.
Any advice or solution would be greatly appreciated.
Martin
Martin Bawden
Fishing Tackle design - Matthews, North Carolina
A. If alcohol inks don't work for you, and paints and powder coatings are unacceptable for some reason, perhaps the best answer would be a PVD coating process, but it won't be cheap.
