Letter 25095
Aluminum Pipe Grinding
Hi,
We manufacture and use aluminum rollers on our printing machines.
While grinding aluminum pipes with the prescribed grade of grinding
wheels, the material still sticks to the wheel surface and the
particles get into the surface of the grinding wheel making it
useless after one job. What is the correct way to grind aluminum
pipes? What grade of wheels is correct for this job?
Amit Ahuja
Printing Machinery - Faridabad, Haryana, INDIA
First, grinding aluminum would not be my first choice I would look
at diamond turned (machined) as a better option with probably as good
a finish as you are getting by grindeng. Next, lots of people
pescribe equipment and procedures and some of them are less of an
expert than I am -and I am not an expert. Aluminum is a very soft
metal and will load a wheel very rapidly unless the wheel has a very
rapid break down (resin binder). Feeds and speeds, type of cutting
fluid and the amount of it will be critical.The grinding might work
if the parts were machined to a point where you only had to grind a
few tenths rather than several thousands.
- FL
I question if you are using the right abrasive wheel. If you are,
a cheap and easy solution might be to use a wax or grease stick
against the wheel periodically. Most fast cutting abrasives wheels
are designed to break down and lose their mass along with the
material being worked.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- Post a new
question or inquiry on a different subject.
